      07-16-2018, 05:01 PM   #1
falconey
Drives: 18 f80cs, 21 f97
Charge pipe failure...
This is always a topic of discussion as a preventive measure. Fortunately when my charge pipe failed I was on my way home and only ten minutes away. I was able to limp home. I also had purchased a used charge pipe as a just in case for my e90, but never used it so had a spare on hand. If you look at where the pipe failed it looked as if someone took a saw to it.
[IMG]undefined[/IMG]
      07-16-2018, 07:59 PM   #2
mcdanielvzw
mcdanielvzw's Avatar
144
Yep. I replaced mine on my 2nd X1 before it could blow, my first one blew with Map 1 on a JB4. Florida heat/humidity is what I'm blaming LOL
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights
Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH
About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake
Sold - 2009 328i - Stock, 195,000 running strong.
      07-16-2018, 08:36 PM   #3
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
Not the higher boost and more heat from jb4
      07-16-2018, 10:39 PM   #4
mcdanielvzw
144
My driving probably would have done it anyway. Drive it like you stole it. Heat and Humidity are key for plastics failing, IMO.
