      03-15-2017, 12:54 PM   #1
modrisco
Drives: 2012 X1
X1 spark plug change
Is there a how to on spark plug change for 2012 X1 anywhere?
      03-15-2017, 01:19 PM   #2
PrematureApex
Remove engine cover (may have to pull cowl first). Unplug coil packs and remove, remove plug, reinstall coil packs.
Not sure what engine you have, but search on the 3 series forums...they'll have both the N55 and N20 DIYs....but it's very straight forward.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      03-15-2017, 01:39 PM   #3
modrisco
Drives: 2012 X1
Thanks for the reply, Engine is 4cyl, 2.8i
      03-15-2017, 02:53 PM   #4
Gamb1t
Gamb1t's Avatar
This might be helpful.
https://www.youtube.com/watch?v=r68aNUBYUnE
Make sure you have a thin walled socket.
The last plug might require removal of the plastic panel for easier access.
      03-15-2017, 03:12 PM   #5
IslandTimes
Drives: 2013 X1 sDrive28i
Just did this last month.
You have to remove the cowl to get started. There are a couple screws and plugs to be undone, and you have to remove the AC filter piece and associated screws to remove the whole cowl. It's easier to get off than back on. Don't force anything when putting it back on, as when it's lined up it will easily seat into place.
Once that's off you can remove the engine cover. The passenger side of the engine cover has what I think is some kind of vacuum line running into it. With a little fooling around this came off pretty easily and went back on without a problem when I was finished.
As for the plugs themselves. I worked one at a time front to back. You don't necessarily need a flexible extension shaft for your wrench, a skinny extension rod should be fine. I used a six, four, and two inch extension in combination depending on the plug.
Everything went pretty smoothly going one plug at a time and torquing to 17ft lbs. The last plug gave me a little trouble in that it was the hardest to reach and I did not push the connector to the coil pack in far enough the first time. The engine threw a cylinder misfire code when I started up; after I cleared the code and re-seated the plug I haven't had any issues.
      03-15-2017, 06:55 PM   #6
D Unit
Drives: 2013 x1 s28i
what's the recommended spark plug interval change?
D Unit
Bay Area, CA
      03-15-2017, 08:22 PM   #7
Gamb1t
Gamb1t's Avatar
Check your manual. IIRC it's every 4th oil change. Although based on research early n20 engine came with NGK SILZKBR8B8S that require replacement frequently. Newer NGK SILZKBR8D8S lasts longer.
      03-16-2017, 07:34 AM   #8
IslandTimes
For the E84 N20 I believe the first spark plug change is recommended at 50K miles.
      03-16-2017, 11:30 AM   #9
vstolpner
Drives: 2019 F39 X2 m35i
Mine came due at 45k mi
Got the dealership to do it on my last free service.
      03-16-2017, 12:57 PM   #10
walendvay
Drives: '11 F25 28i; '13 E84 35i
any guides on how to get to the plugs on the N55?
      03-16-2017, 01:05 PM   #11
vstolpner
Check YouTube for E90 spark plug changes. I believe the cars are identical from that perspective
      03-16-2017, 01:26 PM   #12
PrematureApex
Same as the above. Remove cowl, remove engine cover. May have to swing one of the strut braces out of the way, but no big deal.
Piece of cake.
http://www.e90post.com/forums/showthread.php?t=826823
      03-16-2017, 01:30 PM   #13
walendvay
thx.
      03-16-2017, 02:16 PM   #14
Gamb1t
Gamb1t's Avatar
Aww man my dealership denied me because of CBS. Ugh. Which dealership did you go to in Vancouver? Maybe I should go there for my final free service.
      03-16-2017, 09:11 PM   #15
vstolpner
Langley
They almost denied me too but then I had the service advisor speak to his manager and since I was fairly close in km they threw it in. I think I was at 3500 and they said they only do it at 3000 or something like that.
It's an easy job to do it yourself in about an hour and the spark plugs themselves are quite cheap, so I wouldn't worry about it if the dealership doesn't include it.
      03-17-2017, 02:10 AM   #16
Gamb1t
Gamb1t's Avatar
I go to Langley too!
I know it's easy enough, just in principle i like to have it covered by BMW. Guess I'll check back in when i am near the end of my free service dateline...
      03-17-2017, 02:34 AM   #17
vstolpner
Haha that is too funny!!
Have you asked what your remaining mileage is on the spark plugs?
      03-19-2017, 03:11 AM   #18
kry226
Drives: 2018 X5 xDrive35i M-Sport
Piece of cake.
Yeah, that is a great pair of videos and I'll be referencing it when I tackle my spark plug job here soon. However, I would make a couple of points:
1. I highly recommend NOT using your torque wrench as a regular ratchet. Use it for what it's designed to do...torquing nuts and bolts (and spark plugs).
2. On other spark plug jobs for other vehicles, I sometimes have had problems with the socket getting stuck on the plug down in the engine. Not sure if this is an issue with the N20 or N55, but to prevent this, tape the socket to the extension by wrapping around the outside circumference of the socket/extension before getting to work.
Hope this helps.
2018 X5 xDrive35i M-Sport - Traded
2013 X1 xDrive35i - Sold
1986 320i - Sold
      03-19-2017, 08:13 AM   #19
walendvay
What is your favorite plug?
Denso
Bosch
Seems like there are only two made for the N55 engine
      03-20-2017, 12:55 AM   #20
Carlin/14/E84
Drives: 2014 x1 bmw
Just in time, It was time to change oil and plugs...thanks for the video it will come handy. The socket in question you could buy it https://www.ecstuning.com/b-schwaben...ive/sp-05-12p/
I wish it was a repair/service manual available for the X1 to buy. I always had a service manual for all my present and past beemers, the 318, 3.0 CS, 325i, Z3.
      03-20-2017, 10:52 AM   #21
kry226
Denso
Bosch
I'm going with the Bosch. I've never come across any Denso plugs.
1986 320i - Sold
      03-20-2017, 12:18 PM   #22
Gamb1t
Gamb1t's Avatar
Originally Posted by Carlin/14/E84 View Post
Just in time, It was time to change oil and plugs...thanks for the video.
Resources​ abound. Cross reference with F30 forums for engines - n20/n55. E90 forums on other things.
