      05-18-2015, 08:03 AM   #1
Nova Rounder
Drives: 2015 X1 xdrive 28i M Sport
Front Strut Bar for E84
Has anyone used a front strut bar for E84? If you do, do you recognize a difference in handling especially cornering? What is the best one made? Where can you get it?
Thanks in advance for comments!!
      05-18-2015, 05:09 PM   #2
Shock96
That was a hell of a thing...
22
Drives: 2013 xDrive 35i M Sport
I have only seen one but AC Schnitzer and it is 1400 bucks.
      07-13-2018, 07:11 PM   #3
sudermatt
Drives: 2015 X1 35M
anyone gone here?
there are a couple Front Strut Bars for around 150. Anybody ever do one? what does it do to handling?
https://www.ebay.com/i/381974680630?chn=ps
      07-16-2018, 02:31 AM   #4
dingo ate my baby
dingo ate my baby's Avatar
Australia
Drives: X1 20D Xdrive
I saw that one too. That brand is quite big with the Honda guys here in Australia. I was considering trying one, just haven’t got around to ordering it.
It is simple and cheap, surely it would make a difference?
      07-19-2018, 06:25 AM   #5
falconey
Drives: 18 f80cs, 21 f97
The M sport comes with a strut brace. Exact same as my e90. Maybe you can grab a used one.
      07-19-2018, 10:50 AM   #6
LevinBR
Drives: 2013 BMW X1 xDrive 35i
All trim options (sport line, x line, base, and M sport) come with the same strut tower brace;
https://www.realoem.com/bmw/enUS/sho...diagId=51_7640
      07-19-2018, 12:54 PM   #7
Chicone
Drives: 2015 X1 X35i M-SPORT
What about sway bars? Is there anything out there to upgrade?
-Steve
2015 X1 X-Drive MSport // BMS Intake
      07-19-2018, 07:08 PM   #8
falconey
Ok good to know. Maybe the original poster wants to upgrade. I wrongly assumed he didn't have any strut brace.
      07-19-2018, 07:11 PM   #9
hooligan_G01
Space Shuttle Door Gunner
hooligan_G01's Avatar
6430
Drives: 2022 X3 M40i BG/Taco Red
-Steve
I believe a popular rear sway bar upgrade is the stock bar from the e93(?) M3 convertible (the convertible has the thickest of any of the M3s).
      07-19-2018, 09:56 PM   #10
mwtrogus
Drives: 2014 X1 35i
I have the e90 M3 front strut tower bar setup, seems to work just fine.
Looks good... didn’t honestly feel any difference in handling or stiffness.
      07-20-2018, 08:40 AM   #11
hooligan_G01
6430
OEM or aftermarket?
      07-20-2018, 09:03 AM   #12
mwtrogus
Drives: 2014 X1 35i
Originally Posted by hooligan_clt View Post
OEM or aftermarket?
Stock e90 M3 setup
      07-26-2018, 07:00 AM   #13
PrematureApex
Another vote for a bigger rear sway bar, E93 M3 or aftermarket. Nice difference in handling.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      07-26-2018, 04:10 PM   #14
Chicone
Very cool- I want upgraded sways but I will probably go to wider wheels/ tires in the rear first. I know what a huge difference sways can make because I've done it to other cars.
Is there a part number that anyone has, want to make sure I have the correct one. Is there more than one available? Any links or write-ups? I did some searching but didn't find anything substantive. I should probably start a new thread.
Thanks!
Steve
2015 X1 XDrive 35i MSport //BMS Intake
      07-26-2018, 09:44 PM   #15
PrematureApex
Thanks!
Steve
Post 154 for the M3 Vert rear bar part number.
https://e84.xbimmers.com/forums/show...swaybar&page=7
Posts just above it have the standard M3 rear bar number which will work too (just not quite as stiff).
But again, the rear of the car is all E90. So any write-ups or parts for a RSB that fits an E90 (328/335/M3) will work.
I'll say this, if you ONLY do the vert or regular M3 bar, you can sag the sub-frame low enough without disconnecting the brake lines and wrestle the bar in there. A PITA, but it can be done without completely dropping it. I'm not sure if you go aftermarket M3 bar that you'll be able to squeeze it in without disconnecting the lines.
