      03-31-2014, 12:35 PM   #1
paradoxical3
New wheels came in...time for a fender roll
I'm pretty excited...my new wheels arrived today. Renn motorsport RS51 19in wheels. These will be my daily wheels; they are 9.5 square, ET35 and I plan on running 265/35/19 on all four corners.
These wheels are relatively new to the market (purchased from Sonic Tuning) but are JWL and VIA certified (with TUV pending). They are flow-forged, and only weigh 21lbs each for 19x9.5 ET35 which is amazing.
From what I can tell the construction seems pretty good, and finish is uniform and stunning.
Monday the cars goes in the shop for front fender roll - will be a challenge getting the 265 rubber up front but it should turn out pretty badass.
      03-31-2014, 12:48 PM   #2
Teutonic
Teutonic's Avatar
For the X1?
And how you will deal with the plastic lip on the fender?
I am looking forward to this project.
Good luck!
      03-31-2014, 12:54 PM   #3
paradoxical3
Originally Posted by Tracus View Post
For the X1?
Good luck!
Yep, for the X1. Probably will cut or grind it down if they have to.
      03-31-2014, 01:03 PM   #4
Activ3
clutch-kicker
9
Drives: e46 328i
Looks great! I fit a 9.5 et36 with a 275 in the rear, but it rubbed when lowered. You'll need a spacer up front to fit the 9.5 though.
      03-31-2014, 01:04 PM   #5
paradoxical3
This was one of my questions and got conflicting info from two vendors on this. If that's true, I intend on seeing how much I can roll the fenders and may return the fronts for ET20. But that's very aggressive so figured I'd see if I can get away without a spacer first.
      03-31-2014, 01:06 PM   #6
Activ3
clutch-kicker
9
Drives: e46 328i
With the stock front strut on my sDrive, a 9.5 et28 was VERY close to touching with a 275/30/19. With my BC coilovers, I figure I would need an extra 5mm or so to clear, but I ended up just running a 9" wide wheel instead.
      03-31-2014, 01:34 PM   #7
paradoxical3
Thanks, sounds like it will be close either way. I'm wondering if it will be different for me since I have the M-Sport X35i - the xdrive and msport suspension may have a different strut. Only way to know is to try it I guess!
I do plan on lowering it so will cross that bridge when it comes. I will need to do some research if spacers are safe for the track.
      03-31-2014, 02:31 PM   #8
Activ3
clutch-kicker
9
Drives: e46 328i
My car is an M-Sport as well, but it's not AWD.
As far as spacers go for the track, I just spent this past weekend at Sebring with 10mm non hubcentric spacers up front and had zero issues. I've used spacers on almost all of my track cars and they've been fine as well.
      03-31-2014, 02:51 PM   #9
jm6001
Drives: X1 35i M
Look badass, cant wait to see them on the truck!
      03-31-2014, 07:14 PM   #10
Twix
Twix's Avatar
Drives: 2011 e91
You're going to rub your strut if you have the factory stuff. The aftermarket companies use e90 base stuff with a smaller od than what the x1 has. That's why I went with narrower wheels, I'd rub I'd I went wider
      03-31-2014, 07:22 PM   #11
GTony
Australia
27
Drives: 2015 X3 F25 XDrive 28i M Sport
Hi paradoxical3,
BMW told me max width for front should be no more than 8". I know from this site there are many wheel fitments much bigger.
WOW - 9.5" with 265 tyres . Am looking forward to some CLEAR pictures of the guards and fitted wheels. Good luck.
      04-01-2014, 12:18 AM   #12
wantm135i
wantm135i's Avatar
Drives: x1 35i m sport
what did this rims cost? thanks
      04-01-2014, 09:07 AM   #13
paradoxical3
They are on a promo sale right now for $1366 shipped, which is really a fantastic deal. It almost seems too good to be true - 21lbs, flow formed, JWL/VIA approved - the wheels are stamped with these marking and Sonic Tuning explicitly confirmed they passed, but I still have asked to get in touch with the manufacturer to try to get a certificate.
These are the same price as Apex wheels, look way better, and weigh less? Hard to beat if the safety certifications are really what they say they are.
I think I am going to order a 5mm spacer just in case they can't fit them on.
      04-03-2014, 12:00 AM   #14
back2bimmer
back2bimmer's Avatar
Drives: X1
Can't wait to see 'em!!
      04-03-2014, 12:24 AM   #15
paradoxical3
Thanks! I also ordered a Macht Schnell stud conversion kit, Blox extended length forged lugnuts, and 5mm spacer. Tomorrow I will investigate whether the vac motorsport hub extenders will work...this would give me more confidence in running a 5mm spacer since they are all non hubcentric.
      04-03-2014, 08:35 AM   #16
wantm135i
wantm135i's Avatar
hey para which down pipe would you recommend since burger doesn't sell them any more. i like that yours is a 3" down pipe. any thoughts?
      04-03-2014, 09:20 AM   #17
paradoxical3
I'd just go with the VRSF, they are all going to make the same power and they are the cheapest. You will totally love the downpipe, it was a very big difference in my car. It got me 2mph alone in trap speed.
      04-03-2014, 01:08 PM   #18
mabrahams
Drives: X1 M-Sport 28i
So you were the one that posted this:
What was your setup?
265 all around will be interesting. I'm running 245 19x8 up front; with stock suspension. I think you may be running spacers to clear the struts with a 265. On the rear, you will be fine (Running 265 on 19x9)..
      04-07-2014, 01:49 PM   #19
paradoxical3
So turns out that the car definitely does not need a fender roll for 265 square! You need a 10mm spacer in the front (5mm is too small) with et35 wheels.
The upshot? Since I don't need a fender roll for 265, I will try a 285 square setup for my track wheels
Here's a crappy cell phone picture of what the wheels look like - the car is not lowered yet, I will probably be ordering a new suspension this week and take proper pictures with my camera once the rain stops and I can detail the car.
      04-07-2014, 02:03 PM   #20
Red Bread
Drives: Smog machines
Chock full of win!
      04-07-2014, 02:07 PM   #21
Activ3
clutch-kicker
9
Drives: e46 328i
Looks great! I'm sure 285 will work fine all around.
      04-07-2014, 02:08 PM   #22
Activ3
clutch-kicker
9
Drives: e46 328i
18x9 et17 285/35/18 up front, 18x9.5 et45 295/35/18 in the rear. -2.8* camber F, -2.3* R 0 toe all around.
