      02-25-2022, 06:35 AM   #1
Haileys_Ride
Drives: BMW X1
New member looking for advice.
Hi everyone.
I just purchase a 2014 X1 28i Xdrive. 120K miles.
I had error codes P0172 & P00BD, after some quick google search , I replaced the MAF sensor (Bosch) , spark plugs, oil, air filter, valve cover and gaskets.
Cleared the codes and they keep coming back.
I have a few other random issues, like the driver side doesn't work via switch, all other windows work independently. I can use the key fob to roll down/up all the windows.- *I have already bought two master switches with the same results.
The heater isn't blowing through the front or lower vents, and it doesn't appear to be blowing hot air, nor A/C.
Below is the Error Memory report from Bimmer Code:
Any advice will be appreciated.
00 Safety and information module (SIM)
2 errors
A73E: DC-DC CONVERTER DSC / DXC E84
A6C8: HECKSCHEIBENHEIZUNG_RELAIS
12 Motor electronics
2 errors
2774: 0x2774 Air mass, plausibility: air mass too high
2BC1: 0x2BC1 Mixture control: Mixture too rich
20 Tyre pressure control
4 errors
6054: Error wheel sensor VL
6055: Error wheel sensor VR
6056: Error wheel sensor HL
6057: Error wheel sensor HR
56 Roof function centre
1 error
A670: Error fitting sensor 0xA670
60 Instrument panel
1 error
A56F: CAN_ID_2C3_ERROR_ID-Ausfall_oder_Alivefehler__COMBOX_ECall
62 MOST/CAN gateway (headunit/radio)
2 errors
E190: Ring fracture diagnosis was performed (Error_Ring_Diagnose).
E18F: Central registry does not match the target configuration (Error_Registry_New).
72 Basic body module
1 error
9CBA: Communication with LIN keypad interfered
78 Heating/air-conditioning control
8 errors
9C56: Temperature sensor footwell
9C5F: Temperature sensor ventilation
9C62: Temperature sensor evaporator
9C4C: Footwell flap (LIN)
9C52: Ventilation flap (LIN)
9C48: Mixed air flap left (LIN)
9C49: Mixed air flap on the right (LIN)
9C4A: Fresh air / circulating air / dynamic pressure flap (LIN)
      02-25-2022, 01:34 PM   #2
Gamb1t
Gamb1t's Avatar
How old is your car battery? All these non-related Code emerging together may point to a central issue usually to do with the ECU not receiving enough voltage from the battery therefore triggering random fault codes.
It's worth a look at your battery age and strength.
      02-25-2022, 04:41 PM   #3
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Also be aware that you can't just replace the battery.
You have to register the battery with the car so that it knows to change the way it charges the new battery. Otherwise the new battery will have a very short life.
This post sent using 100% recycled electrons.
      02-26-2022, 04:37 AM   #4
cwickberg
Drives: X1 35i MSport Ultimate,
Why did you buy this train wreck of an X1?
      02-28-2022, 05:33 PM   #5
Haileys_Ride
Drives: BMW X1
Good call, just ordered a battery from Orileys.
Noted, I have Bimmerlink and Bimmercode. Should not be a problem.
Thank you both for your contributions.
