      02-11-2022, 01:33 PM   #1
bosstones
Drives: o_0
One-Time Use Bolts for Underbody Shielding?
My E86 has one-time use bolts (stretched past torque) on its reinforcement plate so it got me wondering if the E84 did, too. Are bolts for any of the underbody shielding one-time use parts?
Now that I can finally open the hood, I can finally start on my maintenance backlog. To do so, I'll need to get underneath but want to make sure I have everything I need before I start. I wasn't having much luck looking this up so I figured I ask this here.
TIA
      02-11-2022, 03:36 PM   #2
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
When you say underbody shielding, are you talking about that big plastic tray screwed to the bottom, that is a barrier between the road and the engine?
      02-11-2022, 06:41 PM   #3
bosstones
Drives: o_0
Inclusive of it. I don't think those bolts are but I'm not sure about the "rear engine undercover", which I also cant find torque specs for.
I'm going to be changing out the trans fluid/pan/filter as well as the coolant and intercooler as part of my maintenance list.
      02-12-2022, 11:06 AM   #4
Gamb1t
Gamb1t's Avatar
IIRC there is a metal shield underneath the engine bay that uses metal bolts. I've removed them for front diff oil change and reused them. No indications that there were one time use. Torqued back up with no problems.
bosstones1154.00
      02-15-2022, 06:09 AM   #5
4_ring_circus
Drives: Corrado, Audi S4, X1 128xi
Usually only bolts that are torque to yield (ex. 90ft lbs plus 1/2 turn) are one time use. The 1/2 turn in the example I gave is where the bolt gets stretched.
I doubt bolts for under shielding are one time use, those shields need to come of for maintenance.
bosstones1154.00
      02-22-2022, 09:35 AM   #6
bosstones
Drives: o_0
Thanks, guys. I didn't think the plastic guard would but one never knows. Are there torque specs for those bolts or just 'tighten until snug"?
