      11-19-2017, 10:12 PM   #1
BeeHemDoubleU IksWane
BeeHemDoubleU IksWane's Avatar
16
Drives: BMW X1
Staggered setup messing with my xDrive?!
Hi guys
I bought 219m M3 wheels for my 2012 X1 28I/xDrive. Here are the spec of the wheels
8,5x18 front ET 29 11,70
9,5x18 back ET 23 12,60
I saw some poster here with those and fell in love. I did my researchs before hand to make sure my staggered setup was within the %range that xDrive allows.
My tires are
Continental dws
245/40r18 front and 275/35r18 back.
Diameter 653.2mm / 649.7mm
Difference in Diameter: percentage = -0.46% actual = -0.14in (-3mm)
I am below the 1% recommended.
My xDrive still act weird. When accelerating from a complete stop it shakes (give littles successive "shakes"), but when cruising on the highway, for example, all is fine..
Do someone know what May be up with this? It doesn't do it with my winter setup, wich is square
Thanks guys.
You talk about German technocracy and you get automobiles.
      11-20-2017, 06:34 AM   #2
Dalco450
Dalco450's Avatar
Drives: X1 M-Sport
I bought a 245/275 setup last month and my X1 was not running fine. KiloTHREE said there ´s no problem with a setup like that... But I changed for 225/255 and now my X1 is running great. I just put my 225/225 winter wheels setup on and the car has the same great feeling. 245/275´s won't work on mine. Maybe X1 from US vs. Canada aren't the same regarding tolerance ???
      11-20-2017, 10:07 AM   #3
kiloTHREE
Drives: '13 xDrive28i
Must be a maple syrup thing.
I ran 215/50/18 in the front and
225/45/18 in the rear for two weeks while I was having tire salesperson problems, whole 'nother story... no problems at all and that's something around 1.5-2% difference.
      11-20-2017, 10:09 AM   #4
kapetajr
Drives: 2015 E84 X128I
I've had 245/40/18 FRONTS & 275/35/18 REARS on my x1 for the past 15,000kms with no issues at all..
2015 E84 x128i/Alpineweiss/TunerWerks Module/E38 MPARS/
1991 Toyota Soarer - turbo6
      11-20-2017, 10:26 AM   #5
0w40X1
Drives: 2014 BMW X1 s28i M Sport
An interesting question is:
Should fronts be the ones that are slightly smaller?
      11-20-2017, 11:18 AM   #6
kiloTHREE
I would assume since it's RWD bias, but I don't know enough about xdrive. Getting good information, not sales speak, on xdrive is difficult at best it seems.
      11-20-2017, 11:34 AM   #7
16
Drives: BMW X1
Would be stupid af
      11-20-2017, 12:30 PM   #8
PrematureApex
Can you describe further? The "xDrive" is shaking? What does that mean? What are you feeling, exactly.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      11-20-2017, 12:43 PM   #9
16
Drives: BMW X1
I'm french so it's hard to explain... From 0 to maybe 10mph, when accelerating from a complete stop like I said, the car seems to stumble (dont know if this is the right Word.) almost feel like I would really quickly and very Lightly hit the brake pedal 3-4 times. Sometimes it's worst and Sometimes It doesn't seem to do it. Seems worse when I goes Lightly on the gas and better when I accelerate faster
It stumble 3-4 times and after that all is fine, weater I Cruise at 30 mph or 100 mph..
Thanks btw for taking of your time.
      11-20-2017, 03:57 PM   #10
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
I have 245/40/18 in front and 285/35/18 in rear and don't have any issues.
      11-20-2017, 03:58 PM   #11
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
Maybe it's your spark plugs
      11-20-2017, 05:28 PM   #12
16
Drives: BMW X1
Would do it whatever wich tire are on.
      11-21-2017, 06:33 AM   #13
Dalco450
Dalco450's Avatar
Drives: X1 M-Sport
Would be stupid af
USA : TPMS
Canada : ABS sensor
Maybe the control of XDrive is more precise. It's a theory, but one thing is sure: I had trouble with a 245/275 setup. It was shaking when under acceleration, downshifting of the transmission was eratic, shifting was harsh and in reverse, there was a strange mechanical sound when turning with steering completly turned on one side. Nothing with 225/255 setup.
      11-21-2017, 12:59 PM   #14
16
Drives: BMW X1
USA : TPMS
Canada : ABS sensor
I paid almost 1000$ for those tires lucky me.
      11-21-2017, 01:09 PM   #15
Njerts
Drives: x3 m40i
The only thing that will mess with x-drive is tire circumference difference. I can't see how staggered can cause this.
      11-21-2017, 02:54 PM   #16
Dalco450
Dalco450's Avatar
Drives: X1 M-Sport
Pareil pour moi. Mais Firestone avait une garantie de satisfaction de 30 jours. J'ai été vraiment chanceux.
If your Continental were brand new, you have a 30 days also to return them
      11-21-2017, 10:08 PM   #17
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
Makes sense because I don't run my tpms sensor on my aftermarket rims. But can you recode it?
      11-22-2017, 12:45 AM   #18
Surferdude12345
Drives: X1
I had spacers for a staggered look. 7.5mm front 15mm rear. A week after I put them on I blew my transfer case. Took off the spacers. Then I had the dealer put a new transfer case in under warranty I had 80k on my 2013. The x-drive act 35l transfer case is sensitive.
      11-22-2017, 07:45 PM   #19
PrematureApex
Many of us have coded our cars to either simply remove the TPMS system, or to remove the TPMS system and add the wheel-speed based system in.
I can't image a scenario where a 1% variation in OD would cause the car to shudder and stumble, and wouldn't flash a TC light or something at you.
That kind of minor diameter difference is probably found on 50% of cars out there just due to uneven F/R tire wear.
      11-23-2017, 06:45 AM   #20
4llr
Drives: BMW X1 2012
Very true. My staggered OEM 19" setup is already off by approx. 2/32 (-0.06" / -0.23%) with 4 brand new tires. BMW does not recommend tire rotation, and have rear biased AWD, so uneven tread wear is somehow expected. so even staggered, with 4/32 thread wear difference, you are still bellow the 1%.
bmwx1sq145.00
      11-24-2017, 05:38 PM   #21
Mr_Jack
Drives: X1 35i M Sport
I am on 265/35/19 & 305/30/19 no issues at all.
'15 E84 X1 35i M Sport
MPI DME Flash - K&N drop in - MPI Chargepipe - Oil T-stat valve - ETS 5" I/C - N54tuning 3.5" downpipe - catless mid section - Dinan 135i rear exhaust - Apex ARC8 18x9/10(255/295 tires) - H&R Sports - Bilstein B6's - F3x M Performance brakes
'02 E39 530i 624whp/558ft-lbs @23psi
bmwx1sq145.00
      11-30-2017, 08:08 PM   #22
Dalco450
Dalco450's Avatar
Drives: X1 M-Sport
So BeeHemDoubleU IksWane, any update of your situation?
