      06-21-2018, 11:26 AM   #1
sudermatt
Drives: 2015 X1 35M
Curious about awd reliability
I currently have a 2014 28 sdrive and want to get an xdrive around the same year but am worried about the reliability.
Should I be worried?
      06-21-2018, 12:27 PM   #2
hooligan_G01
Space Shuttle Door Gunner
hooligan_G01's Avatar
6430
Drives: 2022 X3 M40i BG/Taco Red
No.
      06-21-2018, 01:26 PM   #3
sudermatt
Drives: 2015 X1 35M
I just took my sdrive to a shop to give it a once over...motor and transmission mounts are failing, front shocks are leaking, tensioner belt needs replacing....2500 into this one or use it for a down on the one I really want.
      06-21-2018, 03:47 PM   #4
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
I wouldn't put that kind of money into a car I wasn't keeping. Especially if making a change is immanent.
      06-21-2018, 05:50 PM   #5
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
Get a second opinion..
If moving from RWD to AWD, consider the move from N20 to N55 also!
      06-21-2018, 11:24 PM   #6
E46M3E84X1
Drives: Xdrive 35i
Just bought a 13’ 35i and it’s amazing. I’d say get the car you want. I think the N55 is well balance with the AWD.
      06-22-2018, 10:35 AM   #7
sudermatt
Drives: 2015 X1 35M
I was considering the 35 but the gas mileage hit bugs me.
      06-22-2018, 10:53 AM   #8
bucketfoot
bucketfoot's Avatar
Assuming 10K miles a year, $3/gal for gas and a difference of let's say 2 mpg, you are talking about a difference of roughly $10/month.
      06-22-2018, 02:49 PM   #9
mreric
Drives: 2015 BMW X1
i just got a 28i. AWD. the MPG has not been as great as advertised, but i might be due for new spark plugs.
i am getting about 24mpg.
hoping that spark plug change will push me over the 26mpg. i think i would be satisfied with that
      06-22-2018, 03:42 PM   #10
bucketfoot
bucketfoot's Avatar
I'm shocked that in OC driving you are getting 24mpg.
Driving style and the type of roads you drive on seem to play a big part with the X1. I do almost exclusively street driving and get between 20-24mpg mostly depending on if I drive in sport (most of the time) or normal mode.
Frankly the cost difference is so small that I just drive the way I want to (which I would tend to call spirited!)
      06-22-2018, 03:44 PM   #11
bucketfoot
bucketfoot's Avatar
I was able to get 26mpg driving in ECO mode, by why in the hell would I want to drive a BMW in ECO mode
      06-22-2018, 03:45 PM   #12
kiloTHREE
Drives: '13 xDrive28i
Same here, on long trips I can get 30-32, but for every day commute/errands 23 all the time.
Originally Posted by PrematureApex View Post
What a jackass...
      06-23-2018, 01:31 PM   #13
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
My wife uses our x135 mostly for city driving, and our average is 20mpg, and 18-24mpg is typical. The best I've ever seen on the freeway on a long drive is 28-30mpg.
i think you're right on that the mpg difference is about 2-3mpg
      06-25-2018, 03:49 PM   #14
sudermatt
Drives: 2015 X1 35M
Back to the original question, if you all don't mind.
I ended up getting a 28 xdrive. I would like to know if there is anything I need to be aware of, watch for, warry of.
Thank in advance.
      06-25-2018, 07:04 PM   #15
mreric
Drives: 2015 BMW X1
Thank in advance.
i would take care of the AWD system by changing the fluid in it.
      06-26-2018, 09:09 AM   #16
mcdanielvzw
mcdanielvzw's Avatar
144
In my 14 35i w/ JB4 and catless DP I get 20-26, depending on what I'm doing. I actually got slightly better MPG after installing the DP since I don't floor it during acceleration. Long trips I get 23-27; DD for work is highway with a little city, so 21-23. Strictly city can be 18-21 depending on traffic, but I don't sit in much traffic ever.
Of course this car is no longer my DD, so it will see almost only highway. I'll post up my new DD/work soon
      07-05-2018, 05:08 PM   #17
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
Yes depending on the miles on it.
      07-06-2018, 05:00 PM   #18
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
Check to see if you have the timing chain extension on warranty.
If it's a long term keeper might be worth a proactive replacement.
      07-08-2018, 06:43 PM   #19
sudermatt
Drives: 2015 X1 35M
Good advice...thanks.
