03-26-2019, 10:37 AM | #1 |
Rep 89
Car Running Even Without the Key?
So I've read that bimmer is supposed to warn us if the key is away and I personally saw this warnings many times. What I haven't tried in the past is driving it without the key and from what I read, there is no specific answer to how far it could go. All I know is that if you turn-off the engine, you can't start it back.
So this weekend, my wife drove the car from NJ to NY for about 30 miles (48 km). We passed by the house so I can change so we didn't turn off the engine as they waited in the car. I was a passenger that time and didn't hear any warning sound or see anything on the dash that the key is not in the car. We only realized that we do not have the key when we turned off the car and can't start again. I have the 35i so I dont have ASS. I called my son and learned that the key is in the jacket that I just took off Anyone had this issue? Is this supposed to be how this work? This doesn't sound secure at all. I tested if I'll see the warning sign and its working except in that day when we forgot the key.
2013 X1 x35i M Sport
Past: 2011 Mazda CX7 AWD Sport | 2004 BMW 330i ZSP/ZPP | 2008 Hummer H3 | 2005 Honda Civic VTi | 1997 Honda Civic ESi | 1996 Nissan Sentra SS EXi |
03-27-2019, 02:40 PM | #3 |
Rep 89
Maybe but should it be running that long without a key? Isn't the most secure way is to not even let you change gear if the key is not detected?
03-27-2019, 03:44 PM | #4 | |
Rep 98
maybe they want you to be able to still be able to get to the destination due perhaps an emergency... you know people will sue for anything.... |
03-27-2019, 07:50 PM | #6 |
Rep 410
With Comfort Access (I think standard on all 35i's) you don't need to put it in the ignition. It's nice, until you have an older 3 series without it and have to put the key in....
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake Sold - 2009 328i - Stock, 195,000 running strong. |
03-27-2019, 08:07 PM | #7 |
Rep 92
Oh ok. I don't think our '15 has that feature, though maybe I should look it up. I have heard about people in other cars losing track of their keys while driving and then discovering they couldn't restart the vehicle when they were ready to leave. I guess it's just one of those you have to keep track of. Couldn't have predicted issues like that 30 years ago.
03-28-2019, 09:36 AM | #8 | |
Rep 89
It's still an option even for 35i. I wish there is an option to code what happens when you dont have the keys
03-29-2019, 06:48 PM | #9 |
Rep 410
Interesting, my first base model 35i had comfort access - but it was a loaner car.
03-30-2019, 12:29 PM | #10 |
Rep 172
The easy solution would be to put the key in the slot and not rely on CA.
03-31-2019, 05:38 PM | #11 |
Rep 681
Your car should warn you that it doesn’t detect the key. I’m all too familiar with the dong and key symbol. And yes the car will run until you turn off the engine.
04-01-2019, 07:23 PM | #13 |
Rep 675
Maybe the the CA sensor that detects the key inside the car is shot. Can you scan the car for stored errors? You can probably test it by leaving one key inside the car and try to lock it from outside with the other.
04-08-2019, 01:38 PM | #14 |
Rep 1,706
my friend borrowed my car, started it, went back inside, left the keys and drove 90 miles away with no problem. Once its on, it is useable in every way till its completely turned off. i think as long as you dont double press to turn it off like keeping the radio and dash lights on, you can turn it back on! scary.
04-09-2019, 09:40 AM | #15 | |
Rep 7,528
So that means that when he got out...the driver's door wasn't the one that opened. If you do a test...I bet that the warning about the key being left in the car...as well as an audible sound...is tied to the DRIVER'S door...not any of the passenger doors. This was operator error...not a defect of the car. Under normal circumstances (even average circumstance) a passenger does not usually have the key to the car...the driver does. If the passenger does have the key...its usually because its been given to them by the driver...or the driver has their own key. Passengers can come and go and there is no warning that the key is in the ignition or not in the ignition. I put this in the same category like when people used to lock their old style keys in the car when they were using one of the passenger door instead of the driver's door. If you were to lay the keys down, then proceed to lock all of the doors either manually or using the central lock button...then closed the door...you'd be locked out of the vehicle. But if you did the same thing using the driver's door...you would be saved by the driver's door anti-lock out feature...it won't lock manually or remotely if it is open.
04-15-2019, 01:53 PM | #16 | |
Rep 89
I'm not actually blaming the car. I know its my fault for forgetting the key. I just thought, whats the use of having the car detect the key if it is still going to drive without it?
04-17-2019, 02:15 PM | #17 | |
Rep 172
04-17-2019, 03:21 PM | #18 |
Rep 98
i have gotten a cover for my key that has a clip, it is always clipped to my belt loop or is in my pant, never a jacket. this way i cannot forget the key or lose it
04-28-2019, 08:19 AM | #19 | |
Rep 681
