12-04-2019, 11:38 AM | #1 |
Rep 1
Regular maintenance schedule
I'm a first-time Bimmer owner of a CPO 2015 X1. Eight thousand miles in, I've been loving every bit of my car.
Is there a resource or thread about recommended maintenance items and expected costs available here? I did several searches on this forum and can't seem to find a one-sheet for this information. Thanks in advance! |
12-06-2019, 08:43 AM | #2 |
Rep 485
I have the 14 X1 s28i. The electronic display has the recommended service intervals in it either through the stalk or the idrive if you have.
Change engine oil and filter by at least 12k miles since last one., and use good synthetic oil recommended by BMW. I use Mobil 1 0w40 that was recommended once, and run up to 12k miles. I only have 28k miles on mine since out of country a lot, I just eye ball every thing else on as needed basis......the tires, brake pads, air filter, cabin filter, wiper blades, and battery. Most things that come through dash indicator is to get you to freak out and run to dealer. I put ceramic pads on the rear to stop the overkill dynamic traction control, and preliminary wear out. Google what you asked, and you'll get other BMW owners that made a list for you. |
12-06-2019, 11:54 AM | #3 |
Rep 435
and then 20 conflicting opinions on all of them
12-06-2019, 04:18 PM | #4 |
Rep 158
Let me preface this by saying that I have no problem with Mobil 1, I have used it for years. However, Mobil 1 no longer has the LL01 Spec that is recommended by BMW.
-Steve
2015 BMW X1 35i MSport // BMS Intake Last edited by Chicone; 12-06-2019 at 10:20 PM.. Reason: Misspelling |
12-06-2019, 04:45 PM | #5 |
Rep 485
The spec disappearing could be political or maybe it just won't go the 15k miles BMW uses sometimes.
I have read Mobil 1 0w40 used oil analysis for years, and it nearly always has great data. Since I don't drive much I ran my Mazda RX8 0w40 for 7 years and 7700 miles. Worst it did was thicken slightly. |
12-06-2019, 10:14 PM | #6 |
Rep 5,448
Mobil 1 is good but I wouldn’t run it over 7500 miles in my bmw. Oil changes are cheap Preventative maintenance. Change the air filter and cabin filter every 25,000 miles. Check the brake pads and other fluids and you should be good to go up to 100,000 miles
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
12-28-2019, 08:02 AM | #7 |
Rep 406
Said it many times. FCPEuro and their lifetime replacement, even on oil. Just make sure you return every bottle. If you can get "BMW" oil for $25 why bother with anything else?
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake Sold - 2009 328i - Stock, 195,000 running strong. |
