      02-25-2021, 02:12 PM   #1
beamertheone
Drives: 2008 E92 M3 V8
Daytime running front side lights
My X1 has standard Halogen headlight bulbs and a 501 filament bulb for sidelight (non-halo ring).
I've got some 501 led bulbs to replace the standard filament.
Although I run with the lights set on Auto, the front sidelights are not on until the sensor deems the daylight is low.
Is there a mod to have the led front sidelights on during the day as if a halo or can this to be done by coding.
2008 E92 M3 V8 s65
      02-26-2021, 09:03 AM   #2
Spectralus
Drives: E84 xDrive 23D
Yes it should be possible to code it with NCSExpert.
I coded Halo rings and fogs for daytime and when it got dark, it switched to low beams.
Worked like this when the switch was always set on AUTO. So I never had to touch it.
Pretty sure you can enable the sidelights too.
