      10-03-2016, 04:47 PM   #1
D Unit
Drives: 2013 x1 s28i
X1 automatic vs F30 sport automatic - Huge Difference
EDIT - There is a night and day difference between my x1 automatic and my wife's F30 automatic equipped with the sport automatic option. I knew I wasn't hallucinating.
Seems like F30 guys are coding their nonsport automatics to sport automatics too. Can we do this?
http://f30.bimmerpost.com/forums/sho....php?t=1138452
      10-03-2016, 06:29 PM   #2
Njerts
Drives: x3 m40i
You should try resetting the Adaptive Driver Memory for the Automatic Transmission on both, maybe then they will be the same.
Maybe your wife is more agressive than you😀
      10-03-2016, 06:52 PM   #3
vstolpner
Drives: 2019 F39 X2 m35i
The X1 doesn't have DCT.
      10-03-2016, 06:57 PM   #4
kiloTHREE
Drives: '13 xDrive28i
x2
      10-03-2016, 07:04 PM   #5
D Unit
I guess I didn't Seems like both are ZF 8HP45 automatics. But that being said, the adaptive feature is not turned on in Driver Sport mode so I'm still not sure why the f30/e84 feel so different while driving aggressively through the gears.
      10-03-2016, 08:13 PM   #6
Black Flagged
Black Flagged's Avatar
Drives: M2C
Originally Posted by D Unit
While shifting gears aggressively in my 2013 s28i RWD sport mode, the transmission shifts gears seamlessly/smoothly. However, when I drive my wife's 2013 328i in sport mode, there is definitely some kick after each gear.
They both have the n20 motor with 8 speed DCT, so shouldn't they feel the same?
I pretty sure your 328 has an N26 not a N20, that's why it feels different
      10-05-2016, 12:37 AM   #7
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
It's how it is programmed
A great example is in my F80, when I'm in S2 mode, the gear shifts are smooth, but in S3, there the shifts are much more aggressive and can be felt
Same exactly car and gearbox, just a difference in programming
      10-05-2016, 12:41 AM   #8
D Unit
Is there a way to program the X1 similar to an f30/f80?
D Unit
Bay Area, CA
      10-05-2016, 08:17 AM   #9
bananabun
bananabun's Avatar
171
Drives: E86 M, E92 M
The Alpina transmission flash gets close but, as others stated, the X1 is limited by hardware since it doesn't have DCT.
      10-05-2016, 09:29 AM   #10
vstolpner
The Alina transmission flash only works on the 6-speed 35i variant, it doesn't work on OP's car
bananabun170.50
      10-05-2016, 10:03 AM   #11
bananabun
bananabun's Avatar
171
Oh, okay. TIL.
      10-05-2016, 10:25 PM   #12
D Unit
So, is the general consensus that the X1 with N20 shifts pretty smoothly without a kick? I never drove another x1 before, so I just want to make sure mine is normal.
      10-05-2016, 11:19 PM   #13
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
If gearbox is shifting smoothly and you think the shifts are fast, its good to go
I keep my M3 in S2; there's no advantage to having my neck snapped into the headrest after each gear change
      10-06-2016, 12:17 AM   #14
vstolpner
Yeah, mine shifts just fine. Nice and smooth.
      10-14-2016, 12:31 PM   #15
D Unit
I think I figured out the difference.
f30 328i sport automatic vs x1 s28i automatic (standard)
My wife's f30 has the sport automatic option and it's a night a day difference. Seems like some F30 guys are able to code their nonsports to sports too. Do you guys think it's possible with the x1?
Check this link out.
      10-18-2016, 12:01 AM   #16
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
It might be possible.. not sure anyone has done it though on the forums
      10-18-2016, 09:53 AM   #17
vstolpner
It's the first I'm hearing of it. Given its an F platform I'm not sure it would be possible, but I am very interested if anyone has done anything like this....
      10-18-2016, 11:47 AM   #18
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
F chassis use different transmission control module than E chassis.
      10-18-2016, 01:57 PM   #19
PrematureApex
If you can find an E-series car with a sport-programmed auto...you can likely flash your trans.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      10-18-2016, 04:42 PM   #20
d1saster
Bulgaria
60
I'm not sure if E-chassis 1and z series with 8 gear AT have the sport button.
