      01-26-2016, 09:37 AM   #1
walendvay
Drives: '11 F25 28i; '13 E84 35i
usb memory stick size - 32, 64, or 128?
Hi! Curious of the size, model, and format you are using for USB memory.
I recently tried the following with the following results:
32GB Lexar - fat32 - works well
128GB Sandisk - fat32 - search for artist is painfully slow
has anyone had luck with a 128GB USB drive? if not, how about a 64GB?
wondering if the CIC simply doesn't have enough memory/processing power to index a 128GB, or perhaps I have a failing USB stick.
thanks
      01-26-2016, 10:34 AM   #2
vstolpner
Drives: 2019 F39 X2 m35i
I use a SanDisk 32GB (that really tiny one) and it works really well. Mind you I don't use search, just directory browse.
      01-26-2016, 10:38 AM   #3
walendvay
looking for feedback from those that use 64 and 128 sticks.
      01-26-2016, 12:18 PM   #4
improvius
Drives: 2015 X1 X28i
I've got a 64GB Sandisk Ultra that's plenty fast, though I think it is only about half full. Also, I suspect iDrive maintains its own database of track info for searching, though I could be wrong on that.
      01-26-2016, 02:05 PM   #5
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Do any of the respondents of this thread have the non-idrive stereo, with no "enhanced USB" option? Kind of an aside, sorry...
      01-26-2016, 03:25 PM   #6
walendvay
I drive for me
      01-26-2016, 03:27 PM   #7
walendvay
yes, CIC maintains its own database. What I am trying to find out is the max size before it slows down when you search by artist. I am seeing it with a 128gb drive someone stated 64 worked well.
also curious if the file structure has anything to do with it. I am using fat32. wonder if ntfs improves things?
for the 64gb guy, ntfs or fat32?
maybe I can set a smaller partition and test it out.
      01-26-2016, 05:21 PM   #8
vstolpner
I'm not sure that iDrive can read NTFS... Might be wrong but all of my flash drives are formatted fat32 for compatibility reasons
      02-05-2016, 03:34 PM   #9
walendvay
I think I figured out part of the problem. In OSX (mac), there is a hidden file placed adjacent to every file. It's called an "apple double" file that's hidden with a ._ as a prefix to the file name. I used a utility to "clean" the USB drive and this has increased the speed of the USB drive. Takes about 8 seconds to pull up my artists (previously, it was 30 seconds).
On a side note, I have a loaner 5 series with the NBT nav. The list comes up instantly. Gotta love the increased processing power of the NBT infotainment system compared to CIC (we have CIC in our 13-15 X1s).
      02-05-2016, 04:32 PM   #10
vstolpner
One more reason to never buy a Mac, or any other Apple product.... (keeping in mind that for many people it does have its merit)
      02-05-2016, 05:02 PM   #11
walendvay
easy there, buddy. this is a BMW board.
      02-05-2016, 05:58 PM   #12
vstolpner
Lol I did my best to keep it neutral :-)
But back on topic - would be great if there was an easy way to update our CIC system to NBT... The loading times are annoying.
      02-05-2016, 10:04 PM   #13
walendvay
agreed. However, NBT is a substantial hardware update to drive the enhanced graphics and such. They use a faster processor. I can't recall if they use an SSD. I know for CIC, I've read that others converted the 80GB PATA HD to a PATA SSD. I may try this shortly.....once I get my combox replaced.... (per my other thread).
      02-05-2016, 10:05 PM   #14
walendvay
2016 = NBT. 2016 = look of honda crv and FWD. F*$*$*(Q#(*#*(
      02-05-2016, 10:17 PM   #15
vstolpner
+1
I haven't heard of going the SSD route... Does it make the system significantly faster?
      02-06-2016, 12:03 AM   #16
walendvay
yes, significantly..... will report when I do it. Others have, search CIC = ssd.
      02-12-2016, 12:18 AM   #17
Teutonic
Teutonic's Avatar
I am using 64 super fast, no lag. Play, random, next, previous, etc. Runs normal.
Be aware, NTFS doesnt work, you need to be on Fat.
Also in order to use a biger than 32 stick, you need a special tool to make the bigger sticks Fat.
Search on my posts, there is one title on how to do it. You will also find in there the tool that will do it.
Cheers.
      02-15-2016, 07:48 AM   #18
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
      08-09-2016, 09:23 AM   #19
kiloTHREE
Drives: '13 xDrive28i
Just wanted to let anyone know that searches.
I'm using a SanDisk Ultra Fit 128 GB formatted to NTFS and it works great. I have about 80GB worth of music on it.
exFAT (the original format) was not recognized by iDrive, reformatted to NTFS and it worked like a dream.
      09-14-2016, 06:57 AM   #20
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
Are you able to play movies as well? I'm able to browse the directory in iDrive and see the movies are there but I dont know why mine wont play. I have the dvd in motion activated and verified it works with the physical dvds, but it wont play when i try from a USB.
File formats I've tried are .mkv and .mp4
I use my 8 gb usb drive thats formatted as FAT32. (I use 2-3 movies to test)
      09-16-2016, 04:25 PM   #21
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
You need to activate the additional video formats via coding. Only dvd is activated from the factory.
