      11-19-2018, 02:58 PM   #1
MNX135I
Drives: X1 35I
What preventative maintenance should I do next?
I have 65k miles on my 2014 X1 35i. Replaced oil filter housing gasket after a leak occurred last month, flushed radiator, replaced tension pulley and new plugs. Full synth oil up to date . Considering transmission fluid flush and fill next oil change (68k miles) . Any other recommendations ?
      11-19-2018, 09:00 PM   #2
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
I would add transfer case fluid and differentials. Other than that you have it covered.
2014 X1 Xdrive35i /BMS intake/JB4/ GFB DV/CPE charge pipe/ VRSF downpipe/ Alpina TCU flash
      11-21-2018, 03:52 PM   #3
sudermatt
Drives: 2015 X1 35M
Check the motor mounts....liquid filled....at 78k mine needed replacement.
      11-21-2018, 07:56 PM   #4
Chicone
Drives: 2015 X1 X35i M-SPORT
Interesting- what were the symptoms?
-Steve
2015 BMW X1 35i MSport // BMS Intake
      11-28-2018, 06:39 AM   #5
bvanlieu
Drives: Alpine 335d
62K on ours, did full drive line flush this weekend (two diffs, transfer). Transfer case wasn't as bad as it looks but just took some patience.
I'll be doing the Transmission kit from CTS at 70Kish (ZF has 120KM as top end of service recommendation). I have problem paying more for the ZF fluid, there are cheaper ones out there if you so desire.
- b
      11-30-2018, 12:27 AM   #6
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
Originally Posted by bvanlieu View Post
... I have problem paying more for the ZF fluid, there are cheaper ones out there if you so desire.
- b
What are the other options?
Is this an option?
Liqui Moly Top Tec ATF 1800
