      09-02-2020, 02:01 PM   #1
thecodefather
It's S "A" V !!
Drives: 2014 X1 xDrive35i MSport
LCI vs non-LCI halogen headlights??
So I've been looking around for answers and can't find anything definitive. I found an aftermarket headlight assembly that I really like for an 09-12 X1 with halogen headlights and I'm wondering if it will fit my 2014 X1. The seller says it's only for 09-12, but is there any reason it wouldn't be compatible with a 2014 model? What's the difference between LCI and non-LCI halogen headlights?
The only difference I was able to find were for the xenon lamps where the LCI version has that strip of light on the eyebrow.
Here's the link to the headlights on eBay:
https://www.ebay.ca/itm/Black-finish...gAAOSwUZhbPKs0
      09-07-2020, 03:43 PM   #2
TyHardaway
Drives: 2015 x1 28ixdrive
Those are the depo headlights I installed them in my 2015 they will work with no errors, you just need to code the DRL to the parking light easy to do with bimmercode.
      09-07-2020, 03:49 PM   #3
TyHardaway
This thread might help you out I have had no issues with my set Pulled the trigger on Aftermarket X1 Xenon Headlights https://e84.xbimmers.com/forums/show....php?t=1109510
      09-10-2020, 02:22 AM   #4
nokstar
Drives: X1
I have a 2011 X1 halogen and want to install LCI scoop headlights with rings (original part not aftermarket)
Is it directly compatible with my old X1?
If not is what mods i have to do?
      09-25-2020, 01:01 PM   #5
thecodefather
It's S "A" V !!
The OP in this thread replaces the halogen bulbs with Xenon bulbs and ballasts. I don't really want to go that route and I imagine that that is optional. Are the depo lights designed to work with the Halogen bulbs or is the switch to Xenon necessary?
      12-03-2020, 11:15 AM   #6
thecodefather
It's S "A" V !!
everything I've read suggests that trying to upgrade to the OE Xenons is a nightmare
      12-14-2020, 02:10 PM   #7
TyHardaway
I have the depo headlights installed and I’m still running halogen bulbs I have no errors everything was plug and play
Tags
angel eyes, halogen, headlights, lci, led, non-lci, xenon
