      06-16-2020, 12:28 AM   #1
Walesy
24 cans in a case, 24 hours in a day Hmmmmmm
Walesy's Avatar
Scotland
79
Drives: BMW G30 MSport
Rear Footwell Damp
I was giving the car a really good internal clean this weekend and found signs of water ingress on the rear footwell. It looks to be right in the corner of the inner sill, where it takes a 90 Deg bend, under the seat bench.
The car has a sunroof also, but I believe the drains enter the boot area, so it runs down the channels.
I could be wrong
Any sill drains etc. that I can check for blockages or is there a known issue that needs to be rectified?
TIA
Present: G30 530D XD MSport
E84 X1 20D LUX
      06-16-2020, 05:35 AM   #2
Ja Gio
Drives: X1 xDrive28i, 2013
I don’t know if the X1 is similarly put together, but when this has occurred with other cars I’ve owned, it was an A/C condensation tube up under the dashboard - it had pulled up through the floor. The water would pool in the rear, at the low point within the cabin. Any signs of dampness up front?
      06-16-2020, 05:10 PM   #3
jarsdad1
Drives: 2011 535i, 2015 X1 3.5
Vapor barrier, maybe?
      06-17-2020, 08:19 AM   #4
Kevman
Kevman's Avatar
45
Drives: 2019 BMW X3 x30i
Ever have your windshield replaced? I had this problem, and after putting some silicone on underside of windshield, it went away.
      06-20-2020, 04:30 AM   #5
Walesy
Walesy's Avatar
Scotland
79
Hi guys
Its the rear and it appears to be running down the way from the trim on the sill, as you open the door (if that makes sense)
E84 X1 20D LUX
      06-20-2020, 08:35 PM   #6
jarsdad1
It's the vapor barrier. Plenty of you tube vids on how to fix. You should peel the carpet back and REALLY dry it out before it becomes mildewed.
      06-21-2020, 02:55 AM   #7
Walesy
Walesy's Avatar
Scotland
79
Cool, I gather its door cards off etc.?
I have a used approved BMW warranty, so I have noted it with them as its in for a MOT and fluid service this week. So I will keep at them.
E84 X1 20D LUX
