      02-21-2019, 12:43 PM   #1
rizoo
Drives: BMW X1 XDrive35i
Need your help to make decisions about keeping my car
Hi everyone, I have an E84 35 Xdrive 2015 model and it has around 62000 Km on it.
It's couple of months that this car is out of warranty. so far I've really enjoyed driving it without a single issue. At this point I want to decide if I should keep the car for next 3 years or not, but my knowledge about car is not enough to make that decision. I want to come out with an estimate of how much I need to spend on the car in next 3 years ? what are the major works that needs to get done on this car between 60K and 120K and do you guys have any estimation of cost of it?
Thank you for your help in advance, really appreciate it.
      02-21-2019, 08:15 PM   #2
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
That's really hard to anticipate. Seeing as you're in Canada I would anticipate your car would need a little more maintenance than the same vehicle where I live. I am at 71,000km and plan to hold onto my car for at least the next three years. I do all maintenance work myself and I expect to spend under $2,000 in the next three years if I exclude modification costs.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      02-21-2019, 08:52 PM   #3
mcdanielvzw
mcdanielvzw's Avatar
144
Are you mechanically inclined enough to work on it yourself, at least for non-major issues (not engine replacement, ac work, etc)? That's a contributing factor with any car.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights
Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH
About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake
Sold - 2009 328i - Stock, 195,000 running strong.
      02-21-2019, 09:35 PM   #4
MNX135I
Drives: X1 35I
I have a 2014 same model- your oil filter housing gasket will start leaking soon, I don't know anyone that hasn't had that happen after 70k. It's a pricey repair-at least 1200$ -$1500
Transmission and differential fluid flush will be $600
Other than that I think they are pretty reliable until 120k
      02-21-2019, 11:07 PM   #5
Turbod
Turbod's Avatar
There are a bunch of things that can fail. You just don't know if or when they will.
Water pump
Coolant expansion tank
Valve cover gasket
Oil pan gasket
Oil filter housing gasket
Charge pipe failure
Differentials or transmission leak
iDrive issues
Sensors failing
So far I have put 26,000km on my X1 and haven't had a single issue.
2023 G80 M3 xDrive
      02-22-2019, 09:14 AM   #6
kiloTHREE
Drives: '13 xDrive28i
Hold up, where did you go for that cheap of a trans and diff fluid? Orr?
Originally Posted by PrematureApex View Post
What a jackass...
      02-22-2019, 09:42 AM   #7
mreric
Drives: 2015 BMW X1
do the work yourself and it will be cheap.
mostly fluid changes are what is needed, you cannot predict what will break.
the best preventive is do the maintenance work.
having said that: maintaining the used car is almost always cheaper then buying a NEW car.
      02-23-2019, 05:00 PM   #8
rizoo
When would be the right time to flush tranmission fluid?
      02-24-2019, 10:26 AM   #9
MNX135I
Drives: X1 35I
Garunteed the oil filter housing gasket will fail before 80,000 miles. That will be a 1200$ repair for sure.
      02-25-2019, 11:15 AM   #10
Kevman
Kevman's Avatar
45
Drives: 2019 BMW X3 x30i
2013 with 137k on the clock. Amazing reliable car. 2 sets of tires, front and rear brakes at 100k. Oil change every 10k. No problems with the oil filter gasket. Alot of highway miles, I am sure that helps. Original tranny fluid, not changing it book says its lifetime. Best car I have ever owned!! Drives like its brand new.
      02-25-2019, 01:27 PM   #11
rizoo
So you did not do Transmission and differential fluid flush, and that did not cause any issue for you? also luckily your engine did not have oil leakage issue assuming you have same N55 3 litter turbo engine
      02-28-2019, 12:53 PM   #12
Kevman
Kevman's Avatar
45
Yup been lucky shes a beast.
      03-23-2019, 12:14 PM   #13
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
Keep it and maintain it OP. X135 is awesome
      03-23-2019, 01:22 PM   #14
Gamb1t
Gamb1t's Avatar
The maintenance and repair cost associated to a car of this age should not exceed the cost of a brand new equivalent replacement car.
