      10-06-2016, 07:02 AM   #1
neverdone
Drives: X5, 335, Ford Lightning, 63 me
for you guys that run winters...
you guys that have OEM 19s and go down to 18s for winter, are you guys using 225/45/18?
      10-06-2016, 07:53 AM   #2
kiloTHREE
Drives: '13 xDrive28i
I step down even farther to 17" for cost savings and more sidewall.
215/55/17
The narrower the tire, the better off you are.
      10-06-2016, 07:57 AM   #3
critter
Drives: x1 ///M
yup 17's . clear the front calipers by millimeters. on my 13 x1 msport. sure do like the softer ride compared to the 19 in rubber bands
      10-06-2016, 08:14 AM   #4
PrematureApex
I run 225/45-18, but I'd also consider 235s as well. 245s would look nice, but would be less than ideal in deeper snow. I don't know, I might enjoy the dry performance of 245s if I was running performance winters vs. full-on snows.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      10-06-2016, 11:27 AM   #5
neverdone
ya I was looking at the thread about people wih 17s, but I'm thinking I want to stick with 18s. I'll probably see some deeper snow here and there, so 225/45 is probably my go to.
thanks boys.
      10-06-2016, 12:45 PM   #6
kiloTHREE
Crap I didn't think about that, I'm putting 35i brakes on my 28i.
Is the clearance close on the face of the wheel or the barrel?
      10-06-2016, 01:37 PM   #7
critter
Drives: x1 ///M
brake caliper is the tightest clearance on the inside of the wheel(barrel?) with a i35 x1 m sport. but they do fit and worked great in last years snow
      10-06-2016, 01:56 PM   #8
kiloTHREE
Thanks, hope mine clear, I didn't even bother to check that when I test fit the brakes.
      10-14-2016, 12:26 AM   #9
kry226
Drives: 2018 X5 xDrive35i M-Sport
I step down from factory 18s (225/45/18) to 225/50/17s. More side wall and the tire calculators state it's only about a 4% difference in diameter. Which is pretty good for the speedo and my OCD.
2018 X5 xDrive35i M-Sport - Traded
2013 X1 xDrive35i - Sold
1986 320i - Sold
      10-14-2016, 09:41 AM   #10
BeEmVe
Drives: '14 X1 x28i M-Sport
FWIW we are running 18" in both summer and winter. Being they are not run flats we can toss one in the boot for long trips.
      10-17-2016, 07:29 AM   #11
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
17" during winter, staggered 19" during summer.
The wheel well doesn't have good clearance for larger than 17" if you live somewhere where frozen sludge will stick. The larger sidewall (more air volume) also helps when driving over ice chunks.
For nordic conditions, the X1 is not ideal - there's no room for chains in the wheel wells, regardless of wheel diameter. And no way to switch from AWD to non-differential 4WD. And the tow point is only on one side of the car.
