      07-07-2021, 02:13 AM   #1
backslashv
backslashv's Avatar
106
Drives: 2022 BMW M3 Competition
Tightening torque specs
Hi,
Where can I find the various tightening torque specs for the 2014 x1?
      07-08-2021, 11:22 AM   #2
chance91
Drives: 2011 Bmw 335d
Best option is ISTA+, it has the shop manual built in. The list for torque specs would be miles long, but you can search in ista for each individual procedure.
For certain procedures, it will the the same/similar to an E90, so if you are doing suspension for instance, find a DIY on an e90 x-drive.
For engine work, look for pre-lci F30 for the N20 or late e90 for the n55 engine.
=||=2011 BMW 335D MSport =||= - gone but not forgotten
2008 BMW 335i FBO
2015 BMW x1 35i DD, mhd stg1
2005 MX-5 LS swap
      07-08-2021, 10:35 PM   #3
backslashv
backslashv's Avatar
106
Thank you for your response. I currently need the torque specs for the rear and front brake pistons. I was hoping there would be a PDF of the service manual that has this information.
      07-20-2021, 03:30 PM   #4
chance91
The calipers? Which bolts, caliper carrier to hub, or the pins to caliper?
I'll see what I can find.
Calipers are same as an e90 335i also, so likely same torque source.
What model/ trim?
**found here. X1 35i same calipers as e9x m3.
81 ft lbs for front caliper to hub.
https://www.m3post.com/forums/showthread.php?t=1330067
