      05-10-2019, 09:21 AM   #1
gnulab
Drives: BMW X1 E84
Softer Ride
Hi,
I am seeking a softer ride for my X1. I would say my X1 is one of the earliest model, the E84 sDrive 2.0d 2009-2012 model.
I had switched the RFT for a normal tire when the RFTs had succumbed to wear & tear. The ride is much softer indeed after the change of tires, but I'm pretty sure it could be softer still.
So, do I start with the coil springs? The springs available is the Eibach lowering kit. Or this is a straight forward shock absorber job?
In Jakarta, Indonesia pot holes are aplenty and speed humps aren't made to standard so the rebound stage is pretty harsh.
Thank you
H
      05-10-2019, 10:03 AM   #2
mreric
Drives: 2015 BMW X1
if your pothole are plenty. then you can achieve even softer ride with a higher profile tire. if you got 18 inch wheel switch to 17 and even higher profile tire then the oem.
this way you dont have to mess with the suspension.
      05-10-2019, 06:57 PM   #3
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
I would also go 17's before changing the spring rate and shock rebound.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
Tags
softer ride
