      05-02-2024, 09:40 AM   #1
mdr130
Drives: 2013 BMW X1
N20 Vanos Oil Control Valve
I had an issue with my exhaust vansos solenoid throwing a code so I bought both the solenoids and oil control valves to replace both the intake and exhaust. I wasn't aware that the control valves couldn't be removed from the outside. When I tried to remove the intake oil control valve using the 24mm hex on the end of the valve, it made some odd noises. I think the cam turned and now it will barely run. It is Throwing a code for intake cam out Did I just grenade the motor or can I get the cam back into its correct position?
2013 X1 xDrive 28i. 143,000 miles.
