      03-29-2016, 04:25 PM   #1
ONLYA6
Drives: '20 X3M '19 M2C
MirrorTap wires for radar detector
Any X1 owners with a hardwired radar detector using a MirrorTap on similar hookup into the harness connector able to chime in on wires used?
From checking with my multi meter I believe it is Brown/Black for Ground and Green/White for +12v Ignition power.
Can anyone confirm? Thanks
      03-29-2016, 06:23 PM   #2
vstolpner
Drives: 2019 F39 X2 m35i
I went the tap a fuse approach. Threw in a cig lighter socket by the fusebox and plugged in the original adapter into that, running the wire all the way to the mirror.
This was for a dash cam but it's the same idea
      03-30-2016, 05:30 PM   #3
PrematureApex
http://www.e90post.com/forums/showthread.php?t=97545
Green/white stripe above the mirror I believe is what I used.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      12-31-2018, 01:55 PM   #4
deano
Drives: 2004 545i
Did you ever get a confirmation or validate these wires after install???
thanks,
Dean
