      06-03-2019, 11:00 AM   #1
Consoles
Drives: 2011 X1 20d Xdrive
2011 x1 x-drive trye pressure sensor failed
Hi,
Had a part worn tyre fitted to match the existing tyres due to a puncture, when i go to the idrive to reset the system but the initiate is grey'd out and says tyre pressure monitor failure.
This car does not have tpms which I thought at first it did and was just a faulty sensor.
Any help would be gratefully received
      06-03-2019, 01:45 PM   #2
mreric
Drives: 2015 BMW X1
replace it.
      06-03-2019, 06:20 PM   #3
kringer2
Drives: 2014 X1 28i xdrive
Check to see if you have metal valve stems. If so you do have the TPMS at the valve. I'm not sure o n this but some older (my 2007 X3) systems relied on the ABS System to monitor the tire speed to determine if a tire is low. I would think if there is a fault there you would also have an ABS light, but I'm just guessing on that.
