      02-26-2019, 09:07 PM   #1
Mtpisgah
Drives: 2010 WRX & 2013 X1
My X1 has died
2013 X1
120,000 miles
Cause of death: BMW using a cheap plastic timing belt tensioner instead of metal
My car went into limp mode so I checked the codes, cam shaft timing error. I talked to a mechanic buddy and he said that happens sometimes and recommended a BMW Indy shop. I took it in and they partially dismantled the engine and told me that the tensioner guide had broken down to the point that the cam shaft had cause scoring to the engine and there were shards of aluminum throughout the engine. Ruined.
The fix: replace the engine.
A used engine is about $3000. Labor is $2-3000. Car value, due to the high mileage, is about $6500.
Fixing it is not worth it. The pick and pull yard offered $640. There are a few charity groups who will give me a tax write off for it. Or I can try to sell it for whatever I can get, maybe $2000 if I am lucky.
There is a pending class action lawsuit for this problem but obviously no one knows when it will be settled and what the outcome will be.
If anyone is in the market for a roof rack, rear cargo rubber mat, tow hitch, or anything else that can be easily removed, let me know.
      02-26-2019, 10:40 PM   #2
0w40X1
Drives: 2014 BMW X1 s28i M Sport
Is the plastic white or other color. Which X1 model? What kind of oil and oil change interval?
      02-27-2019, 07:50 AM   #3
Mtpisgah
I do not know what color the plastic was, I did not look at it.
Oil change intervals were as prescribed by the engine management system. When it told me it was time, I had it changed but a trusted mechanic.
It is a 28 x drive.
      02-27-2019, 08:35 AM   #4
kiloTHREE
Drives: '13 xDrive28i
Originally Posted by Mtpisgah View Post
Oil change intervals were as prescribed by the engine management system. When it told me it was time, I had it changed by a trusted mechanic.
Yeah, that was expressively told to me by a few of a local car club of what not to do. Too long between changes.
Hate to say but that makes me feel better.
Very few and far between with those who stick to sub 5-6k oil changes.
Sorry.
      02-27-2019, 11:34 AM   #5
Mtpisgah
The oil change frequency was not the problem, poor engineering on BMW’s part was the problem. Would increased oil changes have caught the problem earlier, possibly. But it would not have changed the inherent design flaw in the timing chain system.
530iDriver1707.50
      02-27-2019, 12:14 PM   #6
kiloTHREE
Again, no offense. I don't trust any timing chain or belt much over 90k.
530iDriver1707.50
      02-27-2019, 05:40 PM   #7
jarsdad1
Drives: 2011 535i, 2015 X1 3.5
Where are you located?
      02-27-2019, 07:15 PM   #8
Mtpisgah
Greenville, SC.
      02-28-2019, 10:04 AM   #9
mreric
Drives: 2015 BMW X1
it would be great to know which version of the timing guide failed. if you get a chance to post a photo it would be great!!!
      02-28-2019, 04:22 PM   #10
05X3lover
Drives: '15 Dark Gray X1 AWD
Sorry about your loss, OP. Why would more frequent oil changes have prevented this, I don't get that comment?
      03-01-2019, 12:36 AM   #11
Gamb1t
Gamb1t's Avatar
Long OCI and ASS lead to chain tension compromise which begins to beat up the plastic chain guides. And before long...shatter...Kaboom...wahhhhhhhh I want mommy.
Anyone that maintains their own bikes will know the importance of chain lube and abrupt chain shocks.
Fyi plastic chain guide is a normal implementation of modern cars.
530iDriver1707.50
      03-02-2019, 11:33 AM   #12
MNX135I
Drives: X1 35I
2013 X1
120,000 miles
Oil changes every 6k
Timing chain and pulley replacement every 90k
No matter what vehicle.
530iDriver1707.50
      03-02-2019, 06:59 PM   #13
themishmosh
Drives: BMW X1 xDrive35i
I would take it to a BMW dealer. Even though it is far out of warranty, the car is not that old and this kind of thing shouldn't happen. Ask if BMW will cover part of the cost out of good will and questionable design. I disagree with those who say a timing chain needs servicing. If so, why doesn't BMW offer any guidance on it. I also disagree that the guide is plastic in most modern cars. It wasn't on a Nissan VQ. As far as I'm concerned, it should last the life of the car.
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
      03-03-2019, 01:04 PM   #14
Gamb1t
Gamb1t's Avatar
Toyota, lexus, mb, Audi, VW, Subaru, BMW......all use plastic guides. Shall I go on?
Engine kaput is pretty definitive to the life of a car don't you think?
530iDriver1707.50
      03-05-2019, 08:32 PM   #15
Mtpisgah
This. I asked the service manager at the dealership where in the manual it mentioned anything about maintenance and replacement of the timing chain and guide. He had to admit that it did not. I have been driving for 33 years and have owned 12 cars. Seven of them have had more than 200,000 miles on the clock when I sold them. I have always replaced timing belts at 80k miles but have never bothered with timing chains or guides.
Cars that have timing belts can have plastic guides because they are going to get replaced at 80k miles. A car with a chain should have a metal guide so you do not have to screw with it, that is the whole purpose of the chain.
      03-07-2019, 07:17 AM   #16
05X3lover
Another case where a manufacturer chooses to cheap out on a crucial part, saving (only) pennies on something that will have catastrophic results if it fails. I'm surprised by all this as well, I had always thought timing chains were not under the same limitations as belts. You can add this BMW decision to the same ones that gave us 'lifetime' tranny fluid, and 10K oil changes.
      03-08-2019, 01:08 AM   #17
Chicone
Drives: 2015 X1 X35i M-SPORT
My sympathies, It’s a shame. Seems like you should be able to get more than 120,000 miles out of a car if it’s reasonably maintained and loved and it sounds like yours was. That said, my last car died at about 124,000 and it wasn’t worth it to repair. I obtained photos of it being stripped later at the reclaimer that were painful. I had put a lot of mods and time and fun things into it. Best wishes to you.
-Steve
2015 BMW X1 35i MSport // BMS Intake
      03-08-2019, 08:54 AM   #18
thimslugga
Drives: 2015 X1 x28i
I've heard about this issue but the information available is all over the place. I've heard certain years after a specific production date are not affected, that BMW extended warranty, etc.
https://bmwtechnician.com/2016/08/07...g-chain-issue/
https://bmwtechnician.com/2017/08/02...-bmw-bulletin/
http://www.rightfootdown.com/cars/au...nents-n26-too/
      03-08-2019, 12:52 PM   #19
mreric
Drives: 2015 BMW X1
based on the TSB from BMW vehicles made before 03/2013 should be concerned ?
i would be concerned for the whole 2013 line up and under- sometime faulty parts can slipped although the changes are announced
      03-09-2019, 04:16 AM   #20
brunis
Drives: X1 xDrive 25i
If this is the N52B30 i am very interested in the transfer case, but obviously not an easy part to remove. But if you sell it to a chop shop, please let me know which one!
      03-09-2019, 02:13 PM   #21
530iDriver
530iDriver's Avatar
Drives: 2017 BMW 530i
It is a 28 x drive.
Yep another N20 engine has bit the dust.
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness....
      03-09-2019, 02:15 PM   #22
530iDriver
530iDriver's Avatar
BMW has substantially revised the onboard oil change intervals. My G30 with the B46 has oil change intervals of no more than 6800 miles or 12 months whichever comes first.
