      02-18-2019, 08:29 AM   #1
bmwDon2018
Drives: bmw
Good Aftermarket Battery?
my 2013 X1 x28i has had a couple long crank starts over the last few days so I am in the market for a new battery.
Who makes good aftermarket battery's? I'm not looking to pay the premium that comes with BMW OEM on a battery. I also have a friend that can register the battery for me after I change it.
Thanks!
      02-18-2019, 09:04 AM   #2
kiloTHREE
Drives: '13 xDrive28i
I just replaced mine last week.
Went with an AGM from O'Reilly's since I have a business account there.
170 out the door.
https://www.oreillyauto.com/detail/b...3/bmw/x1?pos=4
Originally Posted by PrematureApex View Post
What a jackass...
      02-18-2019, 06:43 PM   #3
Sgop335
Sgop335's Avatar
Drives: 07 335i e92, 08 535i
Thanks!
Havent looked at wifes x1 battery, if you can post a pic or specs. Based on that i can recommend good options.
335i e92 TPC 19Ts
      02-18-2019, 08:10 PM   #4
MNX135I
Drives: X1 35I
Thanks!
I have a 2014 X1 35 I. I went to Autozone and bought a Durant's Platinum 190$ out the door. Switched it out myself in 30 minutes. Hook another battery to your terminals in the front so you don't have to reset stuff when you unhook the old one
[IMG][/IMG]
      02-19-2019, 07:33 PM   #5
bmwDon2018
Drives: bmw
Here is a picture, hope this helps!
      02-19-2019, 08:49 PM   #6
Sgop335
Sgop335's Avatar
Here are some options that match exactly...
Exide
https://www.homedepot.com/p/Edge-L4-...4RDS/205342456
Napa / deka
https://www.napaonline.com/en/p/NBP9...archIndex=Prod
Duracell, many coupons
https://www.batteriesplus.com/batter...onal/sli94ragm
Autocraft
https://shop.advanceautoparts.com/p/...000%7CL3*15597
335i e92 TPC 19Ts
      02-20-2019, 11:54 AM   #7
bmwDon2018
Drives: bmw
Thank you!
      02-22-2019, 09:04 PM   #8
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
If you're experiencing long cranks in cold weather that doesn't necessary mean you have bad battery. Make sure you have long drives often to charge it. I'm saying this because most of the X1s come with an AGM battery which is very durable and long lasting.
If you change your battery with the same type make sure you register it. This is required to instruct the Intelligent battery sensor (or system) IBS that there's a new battery and to charge it properly as new.
If you're upgrading or downgrading make sure to code it and register it. Coding is required to instruct the IBS to charge the new battery per new specs.
      03-06-2019, 05:48 AM   #9
bmwDon2018
Drives: bmw
Went with the Duracell, thanks for all the help. Getting the battery Registered today, as well
      03-06-2019, 09:32 PM   #10
Chicone
Drives: 2015 X1 X35i M-SPORT
Did any of you guys buy a bigger one over the stock 80AH?
-Steve
2015 BMW X1 35i MSport // BMS Intake
      03-08-2019, 09:03 PM   #11
mcdanielvzw
mcdanielvzw's Avatar
144
Bigger than the stock battery? This is one of the biggest SOBs I've seen in a consumer car. I think I'l stick with the same when my 5 yr old battery can't crank (as I have mostly highway miles anyway at 35+ miles/direction).
I've so far only had it not crank because I was in ACC for over 30 minutes while replacing 2 of my wiper pumps. I've recharged it, so we'll see how it goes.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights
Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH
About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake
Sold - 2009 328i - Stock, 195,000 running strong.
      03-08-2019, 09:35 PM   #12
Gamb1t
Gamb1t's Avatar
How about Costco agms? I used their non-agm Kirkland batteries on my other cars and they are great. 10 yr warranty too. Pricing is usually decent.
      03-10-2019, 10:36 AM   #13
Chicone
I prefer to shop at Costco, Costco has Interstate batteries. I’ve searched their site and it said they don’t have a battery for my BMW. In other vehicles, I’ve had good and bad luck there with non agm. I had one that failed after 3 months and had to return it.
-Steve
      03-13-2019, 02:08 PM   #14
alden
Drives: X3
Call me cheap but I've used a Walmart EverStart battery for my wife's X3 and my Mini Cooper S and they work great. Look up BMW EverStart, I've see nothing but good reviews. Plus $150-$165 for a better w/ a 3-5 year replacement warranty, Why not give it a shot.
https://wm6.walmart.com/Battery-Finder.aspx
      03-13-2019, 06:04 PM   #15
Sgop335
Sgop335's Avatar
Not sure if cheap is the right word but do you bother to register the battery or know its AH or agm or not?
335i e92 TPC 19Ts
      03-29-2019, 03:12 PM   #16
BriGuy
Drives: '13 X1 35i - Pure Stage 1/FBO
I went with the bimmerworld Optima red top kit. Comes with billet mounts to hold it down, works great. Same one thats made for e90's.
      06-02-2019, 03:32 PM   #17
unixphone
Drives: 2013 X1 & 2014 Z4
Anyone can recommend a good battery that works well with Carly Adapter?
I plan to replace the battery and register it myself.
      06-02-2019, 06:11 PM   #18
themishmosh
Drives: BMW X1 xDrive35i
Just get the same AGM battery that came with the car and you should be fine.
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
      06-04-2019, 12:15 AM   #19
unixphone
How about this?
It says exact fit and AGM battery. I have 2013 X1 28i.
https://shop.advanceautoparts.com/p/autocraft-platinum-agm-battery-group-size-h6-760-cca-h6-agm/10210829-P?navigationPath=L1*14920%7CL2*15000
