      01-25-2022, 11:58 AM   #1
dave14x28
Drives: 2014 X1 x28i
BlueDriver or other OBD adapter for E84 X1?
Hi, any experience with OBD adapters for the E84 X1? Not for coding, but just for diagnostics and live data.
I have an older performance app (for android) that recommended any ELM bt/wifi adapter, but there's different ELM chips, many different adapters that say ELM, many that don't, and cheap knockoffs too I suspect.
A visit to the ELM site confirms what I already knew - I'm not an electronics designer!
I think all I've managed to piece together so far is that the 2014 E84 uses a CAN protocol, which means an ELM 327 or 329 chip is needed.
Looks like BlueDriver is a popular entry on Amazon, claims to be the most capable and the app the least annoying, though not the cheapest - do you get what you pay for?
      01-25-2022, 12:52 PM   #2
dave14x28
well, I did learn from Lemur that the BlueDriver adapter will only talk to their app and vice-versa. Bummer, though not surprised.
So I will have to take a chance with one of the many ELM-based options out there. Hard to tell which ones are any good though....
      01-25-2022, 02:06 PM   #3
Gamb1t
Gamb1t's Avatar
I have 2 BT OBD ELM adapters and 2 K-DCAN cables that work fine with the X1 ECU comms. I use the KDCAN too hook up INPA for deep diagnostics. BT adapters for Torque app for general reads.
      01-25-2022, 06:07 PM   #4
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
I use the MHD orange wifi adapter. Perhaps it works with other apps besides MHD? To connect, you just select the MHD wifi network on your phone.
Edit: I've also used it with xHP, but those are the only two apps I've tried with my car.
      02-16-2022, 03:32 AM   #5
Duchess22
Duchess22's Avatar
Drives: %C2%91%E2%80%9911 e92 335i spo
I too have the Mhd WiFi adapter. I've used it for both the mHD flash and xHP flash. Both flashes are very fast. Less than 2 minutes for initial, and about 30 seconds for subsequent flashes.
Pay attention to the person behind the one in front of you.
      02-16-2022, 10:54 AM   #6
dave14x28
Hi Gamb1t, do you have the 2.0L or a 3.0L?
The MHD wifi adapter mentioned by others here appears to only work for N54/55 engines, not N20, so apparently it makes a difference for that brand (which makes me wonder about other adapters).
