      08-07-2018, 09:11 AM   #1
doakes91
Drives: 2011 BMW X1
USB Retrofit Help
Hello,
I am looking at retrofitting a USB connection to my HU. I believe the only items I require are below;
61119129360 x1 -> Coaxial fakra wire for USB
84109237653 x1 -> USB/Aux Socket
Is the process as simple as plugging these in and then coding the HU? If so, please can someone advise how to code the HU (if required)?
Cheers in advance!
      10-28-2021, 06:31 AM   #2
qchown
Drives: BMW X1 (E84) 20d xDrive
Did you ever get this working?
I have a 2010 X1 with CIC HU and Combox, but no USB (apart from the diagnostics one in the glovebox) and would like to add a USB Pen drive in somewhere.
What option did you have to code and in which module?
      11-06-2021, 07:19 PM   #3
Jbam9
Jbam9's Avatar
Drives: Widebody 130i M sport
The headunit itself has to be coded through the OBD2 port with a laptop. Pretty sure all you would need is the USB cord that has a tan connector going to the CIC HU and then coding
