      08-26-2020, 12:40 PM   #1
forteatwo
Drives: 2014 X1 S-Drive
Slight Change in Tire Size
My current tires are the stock 225/50 R17 on my X1 S. I have an option to buy some snow tires that are 215/50 R17. The rim offsets would be the same or within 2mm of the stock. My question is, is this significant with regard to safety.
Using a tire calculator from one of the nifty online calculators the circumference of the stock tires is 81.2". The Snows, having a slightly smaller sidewall have a circumference of 80". This would create an odometer error at 70 mph on the stock tires of 68.9 mph or about 1 mph with the snows.
One of my thoughts is narrower tires are sometimes better in deeper snow so I do not mind that aspect.
Any thoughts?
      08-26-2020, 01:49 PM   #2
Spectralus
Drives: E84 xDrive 23D
It will work fine, you will have slightly less rim protection since the tire is more narrow.
OEM wheel size 17" x 7.5J, recommended tire width 215-225mm.
      08-26-2020, 02:07 PM   #3
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
If I recall the general rule of thump is to keep the circumference within 3% of stock. In this case you are at 1.5%, so it should be just fine.
This post sent using 100% recycled electrons.
      08-26-2020, 02:51 PM   #4
forteatwo
Thanks to both of you. That is the information I was looking for.
      08-28-2020, 09:54 PM   #5
0w40X1
Drives: 2014 BMW X1 s28i M Sport
I bought my 14 X1 s28i with 8x18 and 9x18 355 wheels so I could put approx 4% lower profile Michelins on it.
Car has no way to know I geared it down since all tires are smaller.
Fronts 225/45r18 went to 225/40r18, and rears 255/40r18 went to 255/35r18.
26" rolling diameter to 25" diameter.
