      01-31-2020, 05:46 PM   #1
citizenboyo
citizenboyo's Avatar
Drives: BMW E84 28i X1
Just installed JB4 and it doesnt work
I just installed the JB4 on my 28i X1 PWG, ive made sure all the connections are clean and everything, there arent any codes that have popped up, and yet I cant use steering wheel controls? Startups are fine, but I dont even know if the JB4 is being recognized by the ECU.
      01-31-2020, 05:57 PM   #2
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Which method are you using to try and enter the steering wheel controls?
For the X1 N20 you need to press the two down buttons (- and down arrow), not the BC button like on some other model vehicles.
This post sent using 100% recycled electrons.
      01-31-2020, 06:16 PM   #3
citizenboyo
Yea, the - and the down arrow, ive tried starting the car and doing it, and even ignition mode to do it, none of them work, tried about 5-6 times
      01-31-2020, 06:46 PM   #4
bucketfoot
bucketfoot's Avatar
You're only showing the two canbus wires, you've got the power wire shoved in with the big fuse in the ComBox... right?
      01-31-2020, 06:51 PM   #5
citizenboyo
Mine didn't come with the red fuse wire.. I recently purchased this so i think the updated versions dont have the fuse connection.
      01-31-2020, 06:53 PM   #6
citizenboyo
Also, how did u place your jb4? Im kind of confused on if u close the ECU box, where the giant sensor wires go
      01-31-2020, 07:09 PM   #7
bucketfoot
bucketfoot's Avatar
I'd have to pull the cowl off to look more closely, but I'm pretty sure I just found a spot where the rubber seal would let the cable run with the cover fitting.
One comment is on your 4th photo, run the cable under the diagonal cross-support instead of over it. Otherwise the cowl is going to crush it.
      01-31-2020, 07:10 PM   #8
bucketfoot
bucketfoot's Avatar
As for the placement, I just kind of wedged it in there.
They are not always the fastest, but if you need additional support I would post here:
https://www.n54tech.com/forums/forumdisplay.php?f=48
      01-31-2020, 07:13 PM   #9
bucketfoot
bucketfoot's Avatar
Do you have either the data cable or the bluetooth adapter to be able to try communicating someway other than the steering wheel controls?
      01-31-2020, 07:15 PM   #10
citizenboyo
No, I didnt think I would need those, never ordered anything extra. I just have the JB4
      01-31-2020, 07:23 PM   #11
bucketfoot
bucketfoot's Avatar
Did you buy it directly from Burger or through another party?
Just thinking at this point you may want to send them an email to see if they have any obvious things to look at.
All your connections look good as far as I can see.
Did you put the caps back on the two wires? It really shouldn't matter, but just thinking it might help the connection if you haven't yet.
      01-31-2020, 07:28 PM   #12
bucketfoot
bucketfoot's Avatar
Did you remove the negative battery lead when doing the install?
      01-31-2020, 07:56 PM   #13
citizenboyo
Yep! Made sure I was very careful during the installation process.
      01-31-2020, 07:57 PM   #14
citizenboyo
I did put the glue caps back, and tried with that. Nothing seems to work
      01-31-2020, 07:57 PM   #15
bucketfoot
bucketfoot's Avatar
I figured I'd ask, as that was the only other thing that I could really think of.
      01-31-2020, 09:25 PM   #16
citizenboyo
Hmm... Ive contacted burger support, and it might be a firmware issue. Sucks cause I dont have a data cable
      02-01-2020, 07:40 AM   #17
bucketfoot
bucketfoot's Avatar
It costs a little more, but I went the bluetooth route. It's much more convenient.
      02-02-2020, 06:40 PM   #18
citizenboyo
So for placement you lifted one of the rubber grommets and put ur cable underneath? Im so confused on where I should put the box
      02-03-2020, 07:33 AM   #19
bucketfoot
bucketfoot's Avatar
I honestly don't recall. I would have to take the cowl off and look to be sure.
Have you heard anything back from Burger yet?
      02-03-2020, 09:10 AM   #20
citizenboyo
Yea, theyre sending me a new motherboard, it might be a firmware issue.
      02-03-2020, 02:28 PM   #21
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
I know I am coming in late but I would have double checked your power and ground. Aside from that you should have the USB cable as a minimum. You should log if you're running the JB4 so you will either need to get a USB to OTG adapter or go with their Bluetooth option.
Someone else asked how the cables are ran into the DME enclosure. There is no ideal way but BMS said to put it on top (the flat part) and press the lid on to smash the cables.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      02-03-2020, 02:59 PM   #22
citizenboyo
Ok i will check tonight thank you
