      06-19-2019, 02:51 PM   #1
Maclure75
Drives: BMW X1
Diagnostics software
Hello, can anyone recommend any decent code reading/diagnostic software that I can install on a laptop and connect to my E84 2011 com’s port so that I don’t need to run to the mechanic every time an error comes up in the dash. Thanks
      06-19-2019, 09:55 PM   #2
kringer2
Drives: 2014 X1 28i xdrive
I use Carly and their OBDII plug. I can read, Clear codes and some limited coding.
      06-20-2019, 03:31 AM   #3
Maclure75
Drives: BMW X1
Thanks - can you post a link to where I can get the software please ? Will it tell me why I get this auto start stop malfunction error ? I believe it is a sensor.
      06-21-2019, 09:59 AM   #4
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
Carli is an app with subscription that you can find on the app store depending what platform you're using android or ios.
The "error" you're referring to might not be an actual error but it just tells you that it's not active due to one of its many conditions not met. It might be your battery is not charged or outside temperature is too hot.
      06-21-2019, 04:50 PM   #5
themishmosh
Drives: BMW X1 xDrive35i
Carly is great. Use their OBDII adapter to be trouble free.
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
      07-12-2019, 12:56 PM   #6
dooferorg
Drives: 2013 BMW X1 xDrive 28i
Yea, this is like on my 2013 X1 where you have the Auto start stop symbol with a slash through it and it's telling you 'Yea, I'd do the start stop thing but there's reasons why I can't'. One of those can be the cabin temp is too high (it's been quite warm out ~90F ) so it needs to have the A/C going.
I've actually been getting in the habit of turn off the auto start-stop (until I can code it to keep its setting between restarts) because I hate that feature.
