      08-03-2020, 12:36 PM   #1
TDR X1 2020
Drives: BMW X1
USB Thumbdrive problem
Hello, I am new to the forum, tried to search something similar with my problem and didnt find so I am gonna make a new thread (hope its not a problem)..
So carrrying on with my problem... I had an USB Thumbdrive in the car for like 2 years from witch i played the music, a week ago I inserted another Thumbdrive and it played like 20 seconds from a song and then appeared like there is no Thumbdrive plugged in. I removed that one and plugged in the normal Thumbdrive that i had for 2 years and it does the same, appearing like is not plugged in. I formated the Thumbdrive and put again music on but still doesnt appear like plugged in. Any ideas of what the problem might be?
      08-13-2020, 11:48 AM   #2
Teutonic
Teutonic's Avatar
Gutten tag!
NTFS doesn't work Are you on FAT32?
      08-14-2020, 08:26 AM   #3
TDR X1 2020
Drives: BMW X1
Yes, its formated fat32, i formated again and still doesnt work
      08-14-2020, 09:06 AM   #4
Teutonic
Teutonic's Avatar
Can you see it on idrive screen?
      08-19-2020, 02:49 PM   #5
TDR X1 2020
Drives: BMW X1
No, it is plugged in the usb port but on the screen is all grey as its nothing plugged in
      08-19-2020, 11:01 PM   #6
Chicone
Drives: 2015 X1 X35i M-SPORT
You don’t say if they are USB2 or USB3 thumb drives.. I’ve had weird issues sometimes with USB3 and switching to a different thumb drive made everything work. Since they are cheap I would obtain yet another one, different brand, and test it. Also, you could try rebooting idrive by holding volume button in for 30 seconds.
-Steve
2015 BMW X1 35i MSport // BMS Intake
      08-20-2020, 02:46 AM   #7
TDR X1 2020
Drives: BMW X1
Its usb2, i already tried 3 usb thumbdrives and it still appears like its not connected with all...i will try the rebooting thing later today
      08-25-2020, 11:08 AM   #8
TDR X1 2020
Drives: BMW X1
Tried rebooting the idrive, the usb thumbdrive still appears not connected even though its plugged in. I already tried 3 different thumbdrives and all appear not connected (all 3 formated fat32, and with various sizes from 8gb to 64gb). I tried plugging an mp3 player in the aux in plug and that works.
      08-28-2020, 11:55 PM   #9
Chicone
Maybe the USB port has gone bad. Have you tried the one in the glovebox?
-Steve
      09-15-2020, 02:52 AM   #10
TDR X1 2020
Drives: BMW X1
Yes i tried it...it doesnt appear also...but i know this is only for updates
      09-15-2020, 12:13 PM   #11
Chicone
My only other thought is that there is a USB Hub that has either gone bad, or the socket itself has gone bad. Or, maybe a fuse is blown to the hub. https://www.newtis.info/tisv2/a/en/e...ephone/HFyxvBt
-Steve
      03-04-2021, 08:22 AM   #12
MON5TERMATT
Drives: 2015 BMW X1
usb?
Is it possible to format a larger usb to work with the port.
i want to run a 64gb usb but you need exfat for that
