04-26-2016, 06:22 AM | #1 |
Rep 638
go flats and repairing them
ok, so I'm getting my go flats tomorrow, I have some options as far as repair ,
was looking at a tire pluggin kit, but I just thought.. could I just not screw a wood screw or similar into a tire as a temporary fix also if I get a screw or nail in the tire, surly it may slow leak, but generally it will only be a problem if you pull it out. and of course a gash you wont be able to fix ideas and thoughts? txs |
04-26-2016, 06:44 AM | #2 |
Rep 534
Go to tire place they will put a plug in for 12 dollars.
Though if you want a peace of mind, have kids in the car and frequently use the highway then buy new tires imho....
04-26-2016, 06:58 AM | #3 |
Dismembered Member
3583
Rep 9,213
Many tire places will not plug run-flats (that's what you mean, right OP?).
+1 on getting new tires. Run flats are the worst thing that could have happened to BMW next to turbocharged engines.
My delivery experience and beach photoshoot here. |
04-26-2016, 07:13 AM | #4 | |
Dismembered Member
3583
Rep 9,213
Hopefully I will have better luck with this one. Seems like BMW got the twin turbo thing right with the S55. N54 was a disaster. I don't miss it at all, shitty motor.
04-26-2016, 07:25 AM | #5 |
Rep 2,793
Just plug it with a kit.....they are runflats after all.....that's what I would do!
Of course the safety Nazi's will tell you to get new tires...but if saving money is your thing and the tires are otherwise good...keep'em! But if your sick of runflats harshness....I see this as a good reason to upgrade to non-runflats and for sake of economics! |
04-26-2016, 07:29 AM | #6 | |
Dismembered Member
3583
Rep 9,213
Was also very loud. Got rid of it around 92K.
04-26-2016, 08:48 AM | #7 |
is probably out riding.
6058
Rep 2,294
Are we calling run flats "go flats" now? Or, is OP talking about running regular tires and asking what he should have with him in case of a flat since his car does not have a spare.
I feel like no one was able to decrypt the OP but that makes me skeptical of my alternate interpretation. OP, if you are switching from run flats to standard tires, you should purchase a plug kit and keep it in the trunk. That or a can of Fix-a-flat is about all you can do outside of buying a wheel from a salvage yard, mounting a tire on and keeping it in your trunk. And no, a screw will not do the trick. Maybe with a tiny puncture, in a pinch, with no other alternative. ....Get a plug kit to keep you on the road and then take the tire to get a proper patch applied to the inside.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
04-26-2016, 08:55 AM | #8 | |
2nd Asst to Dept Undersecretary
6704
Rep 1,298
Drives: People crazy
Don't be mad at OP. They don't speak American up there.
This space for rent.
04-26-2016, 09:27 AM | #10 | |
powerhouse
708
Rep 1,628
Drives: 2014 Porsche 981 CS
Yes, mods, please ban, Verbiage I'm sure they'll get right on that especially armed with the following contribution data: Verbiage: 1645 REP 9,070 POSTS Drives: F80 6MT Join Date: Jan 2010 Some random ass noob... I mean Twinfed1: 2 REP 0 POSTS (excludes OT) Drives: 135i Join Date: Apr 2016 Unless I missed something and you're an Alt (which means you will get banned). Anyway, thanks for teh funny.
no signature. except for this one.
04-26-2016, 09:44 AM | #11 | |
Dismembered Member
3583
Rep 9,213
S55 redlines 7500 RPM.. close enough?
What's 500 RPM difference anyway. BMW turbos do that with their standard rough idle. Quote:
04-26-2016, 11:33 AM | #13 |
Rep 6,218
Just say no to fun flats.
04-26-2016, 02:12 PM | #14 |
I'll get back to you
7556
Rep 2,132
I switched to go flats and got a donut spare tire that I put in the trunk
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
04-26-2016, 02:39 PM | #15 |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
I had my 2006 M3 for 8 years and loved it - great car!! But, it couldn't hold a candle to my M4 - not even close.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
04-26-2016, 03:38 PM | #17 | |
Rep 1
I did the same thing because $65-$100 dollars a tire is cheaper than $150+ a tire. On the other hand, I have to have a donut in the trunk now which takes up a lot of trunk space. It's a sacrifice for going cheap. I honestly regret going to a regular tire. IMO If you buy tires and get the replacement warranty, there is no need to go to a regular tire. Keep the runflats. If you end up having to get a new tire make sure you get the replacement warranty and confirm that runflats are covered. |
04-26-2016, 04:10 PM | #18 |
Rep 470
I'm probably going to get rid of my factory runflats after the tread wears out. I was hesitant because there's no room for a spare but with a kit like this, may not be necessary:
http://www.tirerack.com/accessories/detail.jsp?ID=38 thoughts?
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass ig: @bee2ven |
04-26-2016, 07:36 PM | #19 | |
Rep 398
http://www.walmart.com/ip/Slime-Road...r-Kit/14254132 I use that and one of these. http://www.walmart.com/ip/Slime-Ream...andle/16782759
2016 M4 MW/SS 6mt
04-27-2016, 04:54 PM | #21 |
Rep 686
Drives: 06 330xi (TRADED IN)
People willing to patch it are hard to find; I had to drive about 12 miles to go find a shop that was willing to do it when there are at least 30 tire shops in a 10 mile radius of me... Hint: Any place that sells used tires and barely speaks English (at least here in the LA area)? BINGO.
04-28-2016, 08:57 AM | #22 | |
17963
Rep 9,377
Tags |
trolled tonka hard lol |
