      02-03-2018, 08:21 PM   #1
Roch M4
I /// M FAN
Drives: M4 SS/SO 2016 / X5M C 2023
Replaced OEM Rotors and pads with Cross Drilled And Slotted rotors and ceramic pads
Hi, after 66 000 km on my E84 X1 28i, my rotors and pads were completely worn. So I've decided to look for some aftermarket rotors. After an exhaustive search, I’ve finally ordered a kit with cross drilled and slotted rotors from R1 Concepts (Canada Brakes) with new ceramic pads and sensors.
To make the new installation better looking, I’ve also painted the calipers.
The most difficult part was removing the rear rotors. The handbrake shoes were completely stuck with the inner side of the rotors. After a lot of efforts, I was able to remove them…with the brake shoes, but I was able to replace them after.
jbE840.00
      03-15-2018, 12:55 PM   #2
SharpAndCunning
Drives: 2014 X1 35i
looks good, how much was the kit?
      03-15-2018, 05:58 PM   #3
Roch M4
I /// M FAN
390 $ CAN including delivery
      04-25-2018, 02:11 PM   #4
jbE84
Drives: 2012 X1 x2.8i
Thanks for the post, how does it compare to stock now after you break them in? Less brake dust ?
The stocm brakes on mine should be done by end of the year wanted a set of coated rear rotors so it doesnt rust.
      04-27-2018, 10:45 AM   #5
Roch M4
I /// M FAN
So far the braking force is better that the stock one and I didn't notice more dust, maybe less. So far there is no rust, the appearance of rotors have changed, it looks more like galvanized steel. I will post some pictures
      02-21-2019, 11:03 AM   #6
SharpAndCunning
Drives: 2014 X1 35i
How are these holding up? how many miles do you have now? Any issues?
      02-21-2019, 06:48 PM   #7
Roch M4
I /// M FAN
So far the rotors and brake pads are doing good, I have 10 000 km on them since April 2018, even with our cold winter here I didn't have any issue
