06-08-2016, 03:28 PM | #1 |
2006 330i, TSM, Black, manual, sport
878
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
Silverado Strong: Steel Bed Outperforms Aluminum Bed - 2016 Silverado | Chevrolet
Never thought about this before.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
06-08-2016, 03:52 PM | #2 |
Rep 311
Interesting to see. I'm not a truck guy at all but according to my 'truck' friends, one gets a bedliner pretty much immediately after a truck purchase. I wouldn't know but that's what they all did.
06-08-2016, 03:58 PM | #3 |
Rep 862
Drives: '19 M2 '21 X5
CFRP bed or bust!
Its not even mildly surprising though, and to be honest neither bed is designed to take that kind of abuse so its a fairly irrelevant test. Even the steel chevy bed is cringe-worthily damaged. With a reputable bedliner i think the new ford and chevy beds would perform equally well in that kind of testing, especially in the context of what kind of duty the trucks are designed for. Remember this is part of a paid by chevy advertising campaign and should definitely be taken with a grain of salt. |
06-08-2016, 04:02 PM | #4 |
dances with roads
4722
Rep 4,096
Yikes. I'm a big fan of Ford's push to aluminum, but that is not a pretty sight. I was okay with it up until the toolbox went in. The landscaping block thing was over the top; the toolbox thing was not.
06-08-2016, 07:41 PM | #5 |
Rep 3,468
Trucks these days are the Cadillacs of yesteryear. With options these things go north of 60K easy, 70K is not unheard of. The auto manufacturers know that trucks are the ultimate ****-measuring tool and they are laughing all the way to the bank. I can't imagine doing the stuff that you are SUPPOSED to do to a truck to these suburban warrior d**kmobiles.
06-08-2016, 08:12 PM | #6 |
Rep 2,665
Only matters if this is something you would actually do to your truck. I am often surprised at the tests that have little relevance to the average owner.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
06-08-2016, 09:00 PM | #7 | |
Rep 3,203
06-08-2016, 11:57 PM | #8 |
2JZ-GTE
3032
Rep 3,992
What truck owner actually uses their truck?
06-09-2016, 04:54 AM | #9 | |
Rep 1,602
I tow with it regularly (my 335 sure as hell can't handle towing our boat). The bed is regularly used for hauling either your typical Home Depot project stuff, luggage/gear for long trips or my wake surf boards/wet stuff from our regular boating trips. I considered an SUV, as I just got this a couple months ago to replace my Avalanche. Porsche Cayenne Turbo was at the top of my list for replacement vehicles. I opted against it due to how much I actually use the truck bed (and the bed storage pockets - I use them a lot). I tow and haul shit in the bed. Please explain what I'm "supposed" to do in this truck. |
06-09-2016, 08:11 AM | #10 |
878
Rep 3,699
Looks like the tongue weight might be a little too high. You might want to move the boat back a little bit to help even out the load.
06-09-2016, 09:37 AM | #11 |
Rep 3,554
This will be useful for all those times I drop concrete blocks into the back of my truck from up high....
If you are doing this irl, youre doing it wrong. That being said, Im going to stick with a steel bed because when I let my workers use my truck, Im 99% sure this is how they load it. |
06-09-2016, 09:43 AM | #12 |
Rep 6,299
Because when one buys a truck, a strong consideration is how it can handle taking a load of heavy rocks being dropped into the bed.
Besides, what dipshit gets a truck for that purpose and doesn't get it sprayed with a heavy duty bedliner? These Chevy commercials are almost frustratingly stupid. |
06-09-2016, 09:44 AM | #13 |
Rep 6,299
06-09-2016, 09:47 AM | #14 |
Moderator
7512
Rep 19,368
Check back in five years when the Silverado bed is completely rusted away while the Ford bed is still there, albeit with a few battle scars.
Or, like people already said, there is this great invention called a bed-liner, and its composite construction is probably more durable and more puncture proof then thin metal (of any type) anyway. |
06-09-2016, 11:29 AM | #15 |
Rep 3,256
Chevy is moving to aluminum like Ford did. This ad will bite them in the future.
Kind of like that time where BMW said they don't do FWD cars... |
06-09-2016, 09:51 PM | #16 | |
Rep 1,602
Truck has a 2/4 drop (bought it that way) and I need to adjust the level sensors for the OEM autoride airbags to compensate better for heavy loads. There was also 500lbs of river rocks in the very back of the bed in that pic and I probably had 200lbs of lead in the nose of the boat there. I run a lot of ballast when I surf (2000lbs water, 300lbs lead). I'm happy to say I have no idea who "2 Chainz" is. |
06-10-2016, 01:33 AM | #17 |
2JZ-GTE
3032
Rep 3,992
Bird- Do you run Nitrous?
06-10-2016, 10:44 PM | #19 |
Rep 1,202
06-11-2016, 12:00 AM | #20 |
2JZ-GTE
3032
Rep 3,992
U use nitrous in the other vehicles?, Do tell :-)
06-11-2016, 08:23 AM | #21 |
Rep 1,602
06-11-2016, 10:05 AM | #22 |
Rep 3,468
Good on you for using it. My family bought a 1500 ram at one point with the 5.7 and all we used it for was pulling the 5000lb boat out of the water and short tows. Otherwise, it sat, which usually means a used truck makes a lot more economic sense, but again, if you need to haul 4 or 5 people and have some space for stuff, what you have does make a lot of sense. It's the "too nice to scratch" pretty-boy trucks now that are more about a statement of how manly the guy is, vs. how they are actually used. As they are daily-driven, the % of time where they are "needed" is so small a trailer makes 100% more sense and even renting a truck for the couple days a year may be even better. There are people that use them, no doubt, but the % of use is sometimes so infinitesimally small it in no way justifies them. The auto-companies know that people love these and will go into a huge amount of debt for them.
