      01-09-2019, 09:38 AM   #1
brakeshoe
Drives: 2014 X1 and 2012 328i
2014 X1 Key Fob Issue
The comfort fobs for my 2014 X1 have stopped working. I have checked the batteries and they have a full charge. I even changed one out from another working fob with the same result. Right now I have to even the car using the hidden key from the fob and then I insert the fob in the dash to start the car. Not horrible but annoying.
I am looking for any sort of procedure to reprogram or resynch the fobs myself. I am also wondering if there are any other batteries that might need replacing that might be hidden elsewhere in the car, like the door for instance.
Thanks in advance for your help.
      01-09-2019, 05:23 PM   #2
mreric
Drives: 2015 BMW X1
that is an interesting issue i have not heard of.
usually the key would stop having comfort access and and inserting the fob into the dash usually reset it.
but seem that you actually already did that. i would suggest checking the battery and and make sure you are inserting the polarity correctly of the battery.
      01-09-2019, 06:05 PM   #3
brakeshoe
Batteries are tested and inserted correctly with the flat plus side on the top.
Just a clarification, I used the term comfort access which may not be correct. These keys do not open the car just by being near it. I actually must press a button on the fob to lock or unlock the door. Hope someone has an idea.
      01-09-2019, 08:23 PM   #4
BeEmVe
Drives: '14 X1 x28i M-Sport
Never experience this issue, but sounds like they are no longer sync. I would read the process for adding a new FOB????
      01-10-2019, 08:26 AM   #5
Kevman
Kevman's Avatar
45
Drives: 2019 BMW X3 x30i
I have the same situation on my 2013. Key fob opens door and trunk, but the car will not start with fob in my pocket, has to be plugged into the car to start. Its annoying but getting used to it. Read one posting somewhere that said it could be because the car battery is getting old and putting out slightly less voltage. I am still on the original battery, 6 years old and 134k on the clock. Not changing the battery until it needs to be done, because apparently things then need to be re-programmed. Key fob batteries are fine.
      01-10-2019, 08:50 AM   #6
brakeshoe
Slightly different issue than mine. I can’t use the buttons on the fob to lock or unlock the car. I have to pull the hard key out of the fob. Starting the car is unchanged in that the fob must be inserted in the slot in the dashboard. Something needs to be reset or resynched with the fob but I can’t find the right procedure to do it.
      01-10-2019, 10:23 AM   #7
RXeckless
Drives: 2014 X1 Xline
2014
Same here, but I change the battery!
      01-11-2019, 11:06 AM   #8
Kevman
Kevman's Avatar
45
Did changing the battery solve the problem?
      01-11-2019, 11:13 AM   #9
brakeshoe
No. Not a battery issue. Need help with ideas on resynching or reprogramming
      01-11-2019, 09:10 PM   #10
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
I am having a similar issue with my 2014. I do have comfort access but the fob wont always allow me to open the door or trunk without having to press the unlock button. I have 3 FOBs and replaced the batteries in all of them without any change.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      01-13-2019, 08:25 AM   #11
RXeckless
Nope!
      01-13-2019, 12:15 PM   #12
Chicone
Drives: 2015 X1 X35i M-SPORT
I don’t know enough about it, but wondering if this is a bad footwell module. Seems like it controls a lot of functions.
-Steve
2015 BMW X1 35i MSport // BMS Intake
      01-13-2019, 03:52 PM   #13
orca4wd
Drives: X1, Z3M
Here is a good article to read. Hope this will help out and keep us informed.
http://www.shrani.si/f/k/4j/4sd9KbkF...hicle-elec.pdf
      01-13-2019, 04:30 PM   #14
brakeshoe
Unclear what the last post was intended to help with. It was an incredibly detailed 79 page service manual for series 3. It covered lots of electrical topics but nothing about keyless entry. I hope it is helpful to someone but as the original poster of this thread I don’t think it helps address my X1 key fobs no longer opening or closing the doors. Still open to try any suggestions other than ones about changing the fog battery.
      01-14-2019, 07:51 AM   #15
RXeckless
This problem on mine is only with one fob, my wife's works fine. So that I believe would rule out the module and point to the fob? But thanks for your input.
Maybe time for a poll,
1. one fob
2. both fob's
3. just another way for BMW to pull money out of our wallets
      01-15-2019, 07:51 PM   #16
falconey
Drives: 18 f80cs, 21 f97
It could possibly be the lock actuator. What happens if you press the power lock button inside the vehicle?
      01-16-2019, 10:25 AM   #17
brakeshoe
If you mean the lock button on the dash it works as intended. Pressing the fob buttons while in the car does nothing
      01-16-2019, 12:15 PM   #18
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
I know you tried the battery, but I had a similar problem with my wife's fob where the touch access stopped working and she had to insert the fox to start the car.
Just yesterday I replaced the battery, then did a process I've seen somewhere of inserting the key, starting the car, shutting off the car, removing the fob and repeating.
Everything works as expected now.
This post sent using 100% recycled electrons.
      01-17-2019, 09:47 AM   #19
falconey
Well you certainly have a rare issue my friend. The FOB is synced with the car because you can start the car with it so I don't think pairing the remote is the issue. There must be an issue with the antenna that receives the signal from the key FOB (in this case both FOBs)....wiring, fuse, defective
Also it's interesting that you can replace the battery because I'm pretty sure vehicles without comfort access charge the FOB battery when it's in the key slot. CA remotes don't charge and require battery changes.
      01-17-2019, 11:05 AM   #20
Kevman
Kevman's Avatar
45
Mine works fine except wont start the car unless you plug in the key...
      01-17-2019, 04:04 PM   #21
falconey
Comfort access could be a coding issue or it could be an issue with the CA receiver (not sure of correct name). Do your doors unlock via touch or do you have to press the FOB button?
      01-17-2019, 07:29 PM   #22
Kevman
Kevman's Avatar
45
Thanks bucketfoot, I tried your trick with the key fob and now its working!!
Tags
key fob synch program
