      09-26-2019, 10:50 AM   #1
captret
Drives: 2017 W213, 2013 BMW X1
Question Help w/ Radio Trim
Can someone please explain how to remove this section of radio trim? I know there is a lot of videos on how to accomplish this...but my trim is different. I don't want to damage anything.
Does the whole center console have to be removed first in this case?
Thanks in advance!!! John
      09-27-2019, 07:35 AM   #2
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
You need a long skinny screwdriver to release the bottom tabs. Get low add look at how the tabs operate. Not easy the first time,
2014 X1 Xdrive35i /BMS intake/JB4/ GFB DV/CPE charge pipe/ VRSF downpipe/ Alpina TCU flash
      09-27-2019, 05:31 PM   #3
captret
Thanks "KWX1"
Can you elaborate further on how to insert the screwdriver??
      07-19-2020, 12:06 PM   #4
RBarryB
Drives: 2014 X1 xDrive35i
Final solution?
What was the final solution for your radio removal?
Mine is exactly like yours and I'm trying to add a rear camera to the already existing CIC NAV Pro system.
      01-12-2021, 07:02 PM   #5
proteus290
proteus290's Avatar
Drives: 2014 BMW X1 35I Ultimate
console relocation for android harness install
CIC factory NAV rear camera android 10 upgrade
have the same issue 2 radio screws r behind lower fashia plate for android install wiring harness, metal double din brick in radio hole is not room in there.
console has it trapped
remove 6 console fasteners 2 tens front each side 1 ten nut under brake cover 1 screw right side cover beside right seat 2 more in very back console cover lift panel up it has hooks on it
console trim around shifter snaps up use your plastic pry tools
shifter handle pulls straight up electric plug on some shifter newer handles that r illuminated
lift console up gently and back 1/2'
put plastic pry tool in radio coverlate on bottom has 2 lower tabs that snap in be gentle then it will pop out carefully
u tube also but no one shows this one, pita but do able nothing broken
radio has 4 screws holding double din in all tangled up use your pick on tabs for antenna stuff
k
      01-12-2021, 08:29 PM   #6
proteus290
proteus290's Avatar
Name:  bmw console pic.jpg
read above all this and zero breakage move console back 1/2" all you can get out of it
proteus
      01-12-2021, 08:35 PM   #7
proteus290
proteus290's Avatar
those little ears on console restrict it ? huh no way but get console back a little and its still a tight fit slow and care ful i did it twice allready said CIC radio is a little tricky, right just went to stereo shop and handling it , been messing with USPS agony and dead slow mail
wait till it is finished been waiting for a part a week and a half now
proteus
      03-01-2021, 02:49 PM   #8
jaykaybimmerguy
Drives: BMW X1 - E84
Trim removal
I found this youtube video that shows the center console being removed, giving you that extra bit of room you need to slide the screwdriver in. You'll need to pause as the video is quite fast.
