04-18-2024, 04:31 PM | #1 |
Rep 66
Stainless Steel to Cotton Mesh Air Filters?
Anyone switch over from the stainless steel intake cones to a cotton-mesh style on the SSR top mount intakes? How has your experience been?
Would something like this be fine? (link below). Called SSR and they said they don't make the cotton mesh ones anymore (6 month lead time) and to try any universal 3 inch filter that would clear the bay. Was hoping to get more info from anyone here who's done the swap, obviously noise will decrease going from metal to cotton but the filtering on metal just seems non-existent in my opinion and not worth the tradeoff, especially if you drive through a construction zone randomly. https://www.amazon.com/Pinkhatcat-Pe...cx_mr_hp_atf_m |
04-21-2024, 12:01 PM | #2 | |
BimmerPost Supporting Vendor
1964
Rep 5,017
This intake is in the engine bay? If so i would definitely make the switch to the cotton its ability to filter is much better and the only reason why I could see a meth mesh filter being used if it's in the grill area.
04-21-2024, 05:12 PM | #3 | |
Rep 410
The metal mesh shouldn’t really be called a filter imo lol. I ran it for a few days just to hear it and switched them out to the cotton. I’m in the desert and wanted something that actually filtered, as you mentioned. |
04-21-2024, 07:57 PM | #4 |
Rep 577
Not sure if this will help since what I did was the opposite from what you’re after but I switched from a cotton filter to a mesh filter but instead of using the Blitz steel mesh filters I’m using the BoostLogic stainless filter which seem to be far better made, don’t rust, no center mesh low micron screen that looks as if it can be punctured. So far I’ve got like 10k miles under the filter and no issues with filtration.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
