05-10-2021, 06:26 AM | #1 |
Rep 289
Battery Replacement
After 95K miles and 8 years, time for a new battery!
Have all the tools/software to change, register, etc. new one, but are there any other memory loss or module reprograming I need to do in addition to replacement and registration? I've heard that some folks will keep a trickle charge or even hook up another battery to the posts under the hood to maintain 12V to the car... Is this necessary? Thanks |
05-10-2021, 02:24 PM | #3 |
Rep 485
I have to disconnect my 14 X1 many times during the year. The worst that can happen is it can throw some codes having to do with vanos, etc not shutting down, yet.
Most vids say to not try to jump power when changing battery. You can mess up computer, etc. I also have the 8 year battery with 1/3 of your miles. I used to sell batteries, and noticed that mileage of use can use up battery, not just time in car. My battery sits around 12.0 volts when sitting for nearly a week. I have to catch a friends house to charge occasionally since I live in apartment. |
05-11-2021, 03:25 PM | #4 |
Rep 123
I would advise against keeping 12v to the car as well when you disconnect the battery. People have required a new FRM after doing that before, whether by doing it improperly or some issue with the car, hard to tell. But no risk in swapping a batter as one normally does. Very simple.
=||=2011 BMW 335D MSport =||= - gone but not forgotten
2008 BMW 335i FBO 2015 BMW x1 35i DD, mhd stg1 2005 MX-5 LS swap |
05-21-2021, 09:51 AM | #5 |
Rep 289
So Update
Replaced battery and registered it with Bimmerlink App. Only had to set time, everything else was fine. Battery was $180 for a AGM Platinum Diehard Group 94R from Sams Club. (Fresh Battery, dated april 2021) App was $40. Already had the BT Dongle. Dealer wanted over $500. |
06-02-2021, 11:38 PM | #6 | |
Rep 123
06-06-2021, 12:40 PM | #7 |
Rep 289
06-07-2021, 02:37 PM | #8 |
Rep 485
My X1 s28i 2014 has it's 8 year battery on 36k miles. My plan when I need one is Diehard at Sam's club for $179 and will register with my Foxwell NT elite 510 for $129.
I watch voltage in real time on my Scanguage, so will get a pretty good hint when it goes downhill. |
06-07-2021, 05:28 PM | #9 |
Rep 6
A local indy shop wanted $400 for a new Interstate battery + reprogramming. And they said that Interstate batteries are rebranded Varta OEM batteries. So I went to Costco and got an Interstate H7 94R AGM for $190 and registered the battery myself with the Carly app, which I've had for years and has paid for itself several times over.
06-22-2021, 10:43 AM | #10 | |
Rep 438
06-24-2021, 09:20 AM | #11 | |
Rep 123
I have previously been doing inpa/bmw tools, then moved to rheingold/Ista+, now I'm using bimmercode, and its incredibly powerful and simple. I know a lot of people are a bit worried with VO programing etc w/an app, but so far I've done a lot and no issues. It can do diagnostics/code reading, basic coding, but unlike carly it can do things like edit VO. You would need this for actually adding features like Idrive, Sport brakes (SPBR), Heated seats/sport seats, or Manual swap, etc. So far I've done VO code seat swap VO code SPBR Change coding for key to roll windows up/down fogs on w/high beams digital dash speedometer code out LED warnings for fogs/turn signals Overall, super happy with it.
