01-08-2019, 04:58 PM | #89 |
Rep 17
Just had these put on today! Couldn't be happier.
username - SmithsonianX1 wheels - Beyern Antlers size and offset - 20x9 32 offset spacers - None tires (size and brand) - Toyo Proxes 4plus 245X45x25 suspension - Stock clearance - does it rub (front back)? rolled fenders? No rub!!!
2015 BMW E84 i35 M-Sport
2015 Infiniti Q50 Red Sport 2007 Saab 9-3 t 1999 Volkswagen GTI 1995 BMW 328is |
01-09-2019, 12:35 PM | #90 | |
Rep 26
01-09-2019, 05:59 PM | #91 | ||
Rep 17
01-13-2019, 11:44 PM | #92 |
Rep 71
and I got another set! lol
Apex ARC 8 18x9 ET30(added a 5mm spacer to make it ET25) 255/40R18 18x10 ET25 295/35R18 Super happy with these. I had 19" arc8 back in 2015 and loved them too.
'15 E84 X1 35i M Sport MPI DME Flash - K&N drop in - MPI Chargepipe - Oil T-stat valve - ETS 5" I/C - N54tuning 3.5" downpipe - catless mid section - Dinan 135i rear exhaust - Apex ARC8 18x9/10(255/295 tires) - H&R Sports - Bilstein B6's - F3x M Performance brakes '02 E39 530i 624whp/558ft-lbs @23psi Last edited by Mr_Jack; 03-16-2019 at 10:30 PM.. |
DLag30103.50 |
01-20-2019, 04:07 PM | #95 |
Rep 254
Nice ride! May i know what front lip is that?
Mod List: Twisted Tuning MHD tune, XHP3, ER Charge Pipe, catless DP, ER Competition FMIC, Pure Stage 2 Turbo, PURE High Flow Inlet Pipe, ER Outlet Pipe, GFB DV (Plus), Gruppe M intake, Supersprint full exhaust
03-11-2019, 01:48 PM | #97 |
Rep 246
TyHardaway10.50 |
03-11-2019, 07:28 PM | #98 |
Rep 246
Here's the DD with 437m wheels. I love the look but we purchased this vehicle to be able to go on dirt roads so I threw on the stock wheels back on, but none the less here's pics to share
Spec 19x9 et29 with 255/35/19 |
03-11-2019, 10:24 PM | #99 |
Rep 163
04-16-2019, 03:45 PM | #101 |
Rep 72
Hello, just new to the forum heres my contribution
View post on imgur.com View post on imgur.com View post on imgur.com 235/35/19 front 19x9.5 et38 15mm spacer 255/30/19 rear 19x9.5 et38 12mm spacer Stock suspension Esr lm reps No rubs In front if no spacer, the strut will rub the inner rim |
04-19-2019, 03:07 PM | #103 | |
Rep 26
Mr Jack can you post more pics from rear/front please. Do these stick out? Do they rub? Hows the ride quality? Handling? Thanks Bob |
04-19-2019, 03:11 PM | #104 |
Rep 26
Tires on Stock 225m
Has anyone tried keeping their 225m wheels and putting 245/40 19 up front and 275/35 19 in the rear? Tire rack says that the tires I want (Michelin or Continental ultra HP all season) will fit on those wheels. I am curious about rubbing or poking out.
Thanks Bob |
05-03-2019, 04:14 PM | #107 |
Rep 26
245/40-19 and 275/35-19 on 225m Wheels
Pirelli P Zero All Season 245/40-19 up front and 275/35-19 in the rear. Stock 225M wheels.
Only had them on for a couple of days, no rubbing or poking out. Stock suspension. Review: So far so good. Going from the run flats this is a much better ride and quieter too. There is a little less feel in the turn in (I don't know the term), not quite a sharp I guess. The choice was these or the Michelin ultra HP all season. What I read and was told was that the Pirelli was quieter and the Michelin was better turn in response. Going wider in the front I knew I would lose a little in the turn in but I hoped that the quality of the Pirellis would offset that... not quite. In hind sight, I don't know maybe the Michelin's noise (very little) would have been acceptable but this is my daily driver and I rarely do spirited driving so... I still don't know. (I have a Dinan tune btw). Overall I am very happy. These look perfect on the car. I was afraid that they would barely fit on the rim and look silly but they look stock imo. I will probably try the Michelin next time but hopefully that won't be for a couple of years. Anyway just wanted to post and tell people they CAN get a little wider and better cushioning from their stock wheels (these are 7mm taller radius and 14 overall diameter so not much, I hope this helps with all of the construction in Northern VA rt66). .53% diff front to rear. no errors or anything like that so far. All of the pics are of the rear... front looks similar. What do you guys think? Bob EDIT 7/9/19 Been running on these for a while now and still love the setup but it does rub on the front drivers side in reverse while turning hard left. Not a big deal, small rub but thought I should let people know. EDIT 9/10/22 I swapped back to stock with continental DSW tires (great tires). I have been running those now for about 1 or 2 months now. I like stock better. Specifics: The car handles about the same on stock as with the bigger ones. The old tires were slightly taller (and wider), with the slight increase in height came a taller sidewall. What would happen is that when driving spirited (just a little) the sidewalls would flex more than stock and the tires would wear quicker. The tires were wider though and when turning and the sidewalls flexing it did not hurt handing but the tires would wear more. With the stock tires there is very little sidewall flex. The bigger tires were all season Pirelli, maybe if you were running performance summer tires there would be less sidewall flex and this issue would not have presented itself. I am in Virginia and needed the all season. The alignment would not hold as well either, I found that with the larger size it SEEMED like I had to do an alignment more frequently. There were some other factors here too so YMMV. So in hind sight I would not recommend this setup unless you wanted or could run summer performance tires. Hope this helps. Last edited by Subguy; 09-10-2022 at 12:59 PM.. |
Duchess2244.00 |
05-04-2019, 07:05 AM | #108 | |
Rep 8
05-12-2019, 05:26 PM | #109 |
Rep 1
Just wanted to quickly thank all those that have shared their setups and pictures here! I'm getting ready to purchase new wheels and tires this week and everyone's posts have been really helpful. I can't wait to share my new setup with everyone!
