12-20-2014, 06:39 PM | #45 |
Rep 439
He sends a one-click VM for Mac. So you don't install anything per-se, it's basically just running an app. Couldn't be more simple.
2014 981 Cayman S 6MT, X73 Suspension, SES 2021 X5 45e MSport, Manhattan Green, Coffee Merino, Review & Photos Previous: '18 340 GT, '15 M235i 6MT, '15 i3 REx, '15 x1 xDrive28i |
04-12-2015, 04:56 PM | #46 |
Rep 208
Send me your .MAN file please! i'd like to get some of those features installed, i've got all the equipment and knowledge to code most , but there's a few you listed i'd like
| 2007 328i | Matte Black Grilles | B+W Roundels | Shadowed Letters | B+W Chrome Wheel Caps | 20% Tint | 19" Avant Garde M310 | aFe Pro Oiled CAI | |
04-12-2015, 04:57 PM | #47 |
Rep 439
He just tunnels through the computer, so I never had any of the files myself, sorry.
04-12-2015, 05:09 PM | #48 | |
Rep 208
04-14-2015, 02:56 PM | #49 | |
Rep 675
http://e84.xbimmers.com/forums/showp...8&postcount=23 |
04-14-2015, 03:06 PM | #50 | ||
Rep 208
Most of these still carry over regardless, I've printed the list.. The blank line from bc is going to eliminate it from showing nothing am I correct?
04-14-2015, 05:57 PM | #51 | |
Rep 675
Allow raising sunroof from opened position Sunroof control button double-click speed Brake force display 2 algorithm enabled (during hard braking) Brake force display with rear fog lights (during normal braking) Daytime running lights with brake force display (drl with rear led tubing) Disable dimming mirrors Remote control trunk lid button imediateley release trunk lid Corrected analog speedometer Changed fuel tank reserve warning Probably there's more that I did but can't remember now. I advise to load the nettodat.trc file in NCSDummy and work from there. It is a lot more safer than manually modifying the .trc files. Let me know if you need any of the above functions. |
04-14-2015, 10:47 PM | #52 |
Rep 1
Is there a sticky here, or a site somewhere that will list the available choices? I am certainly willing to pay $70 to have this service, but, of course, want to hit all the bases in one at bat
04-15-2015, 10:35 AM | #53 |
Rep 675
There is no sticky for E84 since all codes for E90 LCI apply for our chassis. I made an excel sheet for my personal use that lists functions I was able to find. Sometimes multiple options throughout multiple ECUs are required for one function to be operational. Let me know if you want it. I'm willing to share it with the community.
04-16-2015, 09:55 AM | #54 | |
Rep 208
04-16-2015, 10:13 PM | #55 |
Rep 675
Attached is my E89 code list (just remove the .txt extension). I always recommend the use of NCSDummy.
Not all codes are tested or needed. To use the filter function you need MS Office 2010 or above. Let me know if you have questions. Last edited by d1saster; 04-17-2015 at 02:17 AM.. |
04-17-2015, 07:13 PM | #56 |
Rep 11
Just got done with Alex adding the alpine b3 trans flash, sirius enable, and a few coding items. We had a small delay as I had a very recent update from the dealer, but he was able to access updated files in just a few minutes, and got it working smoothly.
Sirius sound quality is much better than it was in my jeep or truck, glad we did it. The trans flash feels good also, not too lazy in D, and great in S. Very happy with how it turned out. |
04-21-2015, 05:50 PM | #57 |
Rep 29
How did you manage this? Do you remember what you did? This has been bothering me and I've never been able to fix it.
'15 X1 sDrive28i
04-21-2015, 11:31 PM | #58 |
Rep 675
ECU: KMBI
Version: KMBI_PL2.C09 Function: C08_K_ZAHL_TACHO Description: IMPULSES PER KILOMETER FOR SPEEDOMETER Default option: werte_06 (Comment: E84) Changed to: werte_01 (Comment: E8X+!E89+!E84+!(E82+N54B30T0)) Did the same with C08_K_ZAHL_TACHO_KOMPL Basically I am tricking the car to think I have different tire circumference. The result is about 1 mph difference at 70 mph. |
10-29-2015, 03:33 PM | #60 |
Rep 27
Other apps than Carlys?
This is a great thread.
I have successfully coded a few things with the Carly app for BMW (popularly called BMWhat if I am right). However I would like to do things that the app does not offer. For example I would like to disable the seat belt alert. Has anyone tried other apps to code their E84? |
10-29-2015, 06:08 PM | #61 | |
Rep 545
Drives: x3 m40i
Look under "warnings" for seatbelt reminder. Last edited by Njerts; 10-29-2015 at 06:21 PM.. |
10-29-2015, 10:05 PM | #62 |
Rep 23
seat belt warning
i could not code out the seat belt warning with carly software until the last ios release V20.2-4. it came out a couple of weeks ago and added the CSM module coding for the E84.
Like a dream. i hope they can add the idrive nag screen coding soon as well. |
10-29-2015, 10:08 PM | #63 |
Rep 2,404
I know it's a PITA, but take the time to get BMW standard tools/ncs expert up and running and start coding for real.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
11-11-2015, 08:08 AM | #64 |
Rep 27
Farewell lights does not code
I have succesfully used the Carly app and bluetooth device to code a few modifications. But the Farewell lights function does not work on the car, it did not work before I bought the coding app either. Certainly I have coded both its activation and duration. Is there anything special to this specific function that I should be aware of?
It does work both if you lock the car or not, doesn't it? |
11-11-2015, 02:08 PM | #66 |
Rep 27
